NOT GOING TO HAVE MUCH LUCK ON THAT UNLESS YOU CAN SET THE BROWSER TO RUN THROUGH A PROXY SERVER. BUT MOST SETTINGS ARE LOCKED OUT TO CHANGE THAT.
I cannot endorse using public equipment in ways not intended.
But there are useful situations for knowing how to get past content filters. Seeking content while in repressive countries, or even in a free country like the U.S. often require the ability to find information others want blocked.
The principle way around content filtering is to use a proxy server. There are a number such as proxify.com. I won't list any here, but you can google 'public proxy' or similar terms and find them even from most restricted equipment. Proxy servers ask for the information for you, so while the proxy server is not blocked, it can access the page or information you want and display it in a window within a window.
A second way to get to blocked sites is via a translation site (also a proxy). Google translate or Altavista.com will similarly go to a site and translate them inside their results window. The trick is getting the translation from English to English, which I'll leave you to figure out.
Regarding YouTube in particular, you can search for 'view youtube from restricted sites' and get results like this YouTube video. http://www.youtube.com/watch?v=Zuv1PAd1IAU
Of course, you'll have to watch that at home.
you need to contact your network administrator in order to access a site that is blacklisted. Assuming you have his consent, you can use a proxy, that is a server through which you can surf the web bypassing your network's blacklist. To setup a proxy, just go in your browser settings, and add a proxy using the information you can find in this site:
www.proxy-list.org
http://www.proxy4free.com/
As I have already said, you can use this method only if you have your network administrator's permission.
Hope it was helpful,
Franz
Use a proxy website such as:
Link
You will be able to browse the whole internet without any limitations.
Good Luck!
Use an online proxy like http://hidemyass.com/. Just put http://youtube.com/ into the box on their main page and press "Hide My ***" and it should proxy the page for you. Alternatively, this direct link should take you to their homepage: http://4.hidemyass.com/ip-1/encoded/Oi8vd3d3LnlvdXR1YmUuY29t&f=norefer
Bear in mind that proxies are slower, and easily overtaxed. If hidemyass.com is also blocked, there are a bunch of other easy proxies out there:
https://aniscartujo.com/webproxy/ https://browse007.com/ https://enoughschool.com/ https://hidemy.biz/https://nobodycanstop.us/ http://polysolve.com/ https://schoolisgood.com/
You can try to use an anonymous proxy service such as
http://www.youhide.com/
Enter the url that you would like to visit and all of the content will be forwarded through this site.
You can try a proxy, like anonymouse or kproxy, but a lot of them won't let flash through, or it will be exceedingly slow. Try using your phone, or you might have to wait until you get home.
Unfortunately the only way around is to ask to unblock it or used a proxy.
SOURCE: my school has blocked a
Sorry,
but if the school has a block set you will need Admin. rights to
unblock it. Any attempt you might make will just fail or worse you might
loose all your network rights.
The use of a "Proxy Server" to bypass a blocked site is also unwise, if a
school and/or company spends the time and money to set up a block they
include the proxy's too. Thus setting off a Red Flag Warning letting
them know whom (you), what (the proxy), where(facebook or other apposed
sites), and location/time (your computer/time you did it). This is a
High$$$ service they provide and yes their that good.
Thanks for choosing FixYa, If you find this helpful please vote and leave a comment.
SOURCE: how to unblock sites straight
You need to talk your Administrator to unblock those sites, you CANT do it on your own, because you dont have the privilidges. Sorry.
