Televison & Video Logo
Posted on Mar 01, 2011
I have 1 tv Thomson 32E92NH22 LCD and i lost the manual.I'm trying to get it hanged on the wall.No ideea what tipe of screw i need to conect the tv to the wall hanger.Can somebody halpe me?Thanx a lot.Simona
Anonymous
Level 1:
New Friend:
  • Contributor 4 Answers
  • Posted on Mar 01, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
2351
Points
13
Hi mona_77a,
You can find the manual for your TV here.
Your Thomson TV is compatible with a VESA FDMI (Flat Display Mounting Interface.)
These typically use "VESA screws."
VESA screws tend to be metric sizes of M4 (0.7mm pitch). The length is typically 10mm, but would depend on the bracket (if you don't have a gauge handy, just put a small stick of some sort in there and mark it off with a felt pen, then measure).
Washers are a really good idea, especially if you decide on thumbscrews with plastic heads.
You may be interested in eHow's tutorial on how to mount a flatscreen TV to a wall. This is for a 42 inch screen, but the same rules should apply with a 32 inch.
  • Open Link in New Tab
  • Download
Need to know TV Stand Screw sizes
To know more about this, you have to download the repair manual to this set. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy.
1helpful
2answers
Support thomson roc 4239
new remote control for sensia pure radio has new barreries in it can you tell me whyit does not work
Thomson scenium 30lcdb03b manual
this tv is old now and thomson no longer have them in stock
the menu on the tv is very good and should cover all conections and inputs and tunning
1helpful
Trying to figure out how to convert the base to a wall mount since it appears that it is set up to do this.
first get a wall mount kit. ikea sells them cheaply.
there should be 4 screw holes on the back of the screen. screws goes in there.
first drill 2 holes on the wall
mount the ikea kit using expanding bolt
then screw in the ikea kit on the monitor
just hang the monitor on the wall side.
but..... 15 inch is a bit smallish for wall mount... dont ya think?
I have a 27" screen
these where supplied with a wall bracket from new. Check with www.tvs-services.com they may be able to supply.
I'm trying to hang my tv "Lcd Thomson 32E92NH22"
in the manual there is now screw size specified. there is only a notice about VESA mounts.
here is a link to the manual, so you can have a look yourself: http://safemanuals.com/user-guide-instructions-owner-manual/THOMSON/32LB130S5-_E
greets, b.
How can use to LG LCD tv in wall hang
First you get the wall hanger. Screw one part to the wall. And then screw the other part to the TV. then you hang the TV on the part screwed to the wall.
Hope this solution has been helpful?
COD PIN FOR Tv-Thomson 21DC320, Tipe 507RG/ITC008
Sostituire la 24Wc08P con una nuova. Substitute 24WC08P with a new one. In this model it's very stressed and since it's a flash memory it has a limited number of writes. Ciao
1helpful
2answers
Thomson tv
http://online.projectordoctor.com/Projector-TV-Lamps
http://beamerlampen.biz/projector-bulbs/projector-lamp-Thomson-44DLW617-Nr-5400.html
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
