All of the drivers for that motherboard are here: http://www.asrock.com/MB/download.asp?Model=775i65G&o=All
For no audio solution in ASRock 775i65g just download this http://www.asrock.com/mb/download.asp?Model=775i65G&o=XP
we i have done this b4..problem solve..try it
While Asrock does not have Windows 7 drivers poster on their site, many people have had Windows 7 running on that mother board for awhile now. Almost all of the drivers for the integrated devices for that motherboard are already in the Windows driver library.
The only one that appears to be uncovered is the Audio driver. However, the Windows XP Audio driver should actually work fine in Windows 7.
Good luck and please let me know if I can further assist you.
Drivers:http://www.asrock.com/mb/download.asp?Model=775i65G&o=XP
Regards,
KYTechnology
Asrock 775i65g does not support windows 7 at this time
SOURCE: I need drivers for Asrock 775i65G, im runnig vista ultimate ?
You wont find them at asrock.com because it is not certified for vista.
you can contact them at
http://www.asrock.com/support/TSD.asp
Mark
SOURCE: my motherboard's drivers are not supporting in windows 7
if asus.com drivers arnt working then the only other thing you can try is looking at the additinal updates in windows update sometimes there are driver updates in there.
SOURCE: original driver of asrock 775i65G motherboard was lost
i want asrock 775i65G motherboard realtech K high degination audio driver.
SOURCE: 775i65g Drivers for windows 7? please help
windows 7 will use the xp or vista drivers.
you may need to install it manually
1.) click start
2.) right click computer
3.) click properties
4.) click device manager
5.) make sure your driver cd is in the cd drive
6.) right click any device with a yellow marker and select update driver
7.) follow the on screeb instructions for windows 7 to browse and install the drivers for you.
If you have an internet connection run windows update
the drivers will be in the updates.
if you have to download the drivers then u will need to unzip it to a folder and specifiy that folder when you choose to update your device. (6.7 above)
drivers can be downloaded from the manufactures web site for your device.
http://download.cnet.com/motherboard-driver-audio-cmedia/3000-2110_4-130905.html
http://download.cnet.com/via-vinyl-ac-97/3000-2120_4-10163027.html
http://download.cnet.com/jetway-motherboard-driver/3000-2098_4-163033.html
http://download.cnet.com/Realtek-AC-97-Driver-Windows-Vista-Windows-7/3000-2120_4-10962344.html
Realtek AC
http://download.cnet.com/Realtek-High-Definition-Audio-Codec-Windows-Vista-Windows-7-32-bit/3000-2120_4-10788600.html
http://www.freeware-downloads.com/soundmax_integrated_digital_audio_driver_v.htm
SoundMax Integrated Digital Audio Driver v hope one of these helps
