Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
Posted on Jul 29, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Washer will not Spin during SPIN CYCLES
My washer will fill with water, it will spin both ways during the wash cycle but when it goes to the spin cycle you can hear the machine draining the water but it does not spin. It will then go onto the rinse cycle where it will again spin both ways and then you can hear it start to drain and go into the final spin cycle but the machine does not spin for it. Help PLEASE! My Whirlpool Ultimate Care II makes a terrible sound, and doesn't spin hard enough to remove the water. It makes a clang clang sound.
  • 1 more comment
  • nagus14 Aug 07, 2008
    My Ultimate Care does the same thing.It will wash and agitate in both directions.It will not spin during the wash cycle or the rinse cycle,except for a small loads.I think for small loads. I have checked my coupling and it is good shape.I need to know what to look for so I fix or do I just need to buy another one.
  • Anonymous Mar 15, 2014
    It will pump out water and spin but will not fill up with water during the wash cycle
  • Anonymous Mar 17, 2014
    Whirlpool aa1200
john gagnon
Level 3:
  • Master 943 Answers
  • Posted on Sep 11, 2008
john gagnon
Master
Level 3:
Answers
943
Questions
Helped
324096
Points
2163
Thanks for the question If your washer sorta spins and washes ok, your problem is with the transmissionTHanks for your question THe Appliance doc
5 Related Answers
TheMobilian
Dan Webster
  • 8221 Answers
  • Posted on Jun 18, 2010
SOURCE: my whirlpool ultimate care II washer will fill and
Must be the lid switch
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Anonymous
  • 262 Answers
  • Posted on Dec 03, 2007
SOURCE: Whirlpool Ultimate Care II washing maching but will not spin.
lid switch is bad chance are you can by pass this by removing the timer header and crossing the outer wire on the lid switch that it mounted closest to the lid not the power cord this will tell you if you need a switch
Anonymous
  • 351 Answers
  • Posted on Mar 09, 2008
SOURCE: Whirlpool Washer won't drain or spin
check the lid switch operation,not sure what the noise could be maybe somthing stuck in the pump? hope ths helps unless the contacts in the timer are faulty i have opened up a few timers and fixed the contacts short term.
honeymokey
honeymokey
  • 3113 Answers
  • Posted on Jun 18, 2009
SOURCE: Whirlpool Ultimate Care II washer fills with water and stops
Lid switch. Push down on lid.
Anonymous
  • 5911 Answers
  • Posted on Jun 30, 2009
SOURCE: whirlpool Ultimate Care II Washing Machine Rinse cycle not workin
Most of these spin related problems are attributed to a lid switch malfunction. A washer that fills and doesn't do anything, or stops right after the wash cycle and then does not advance to the rinse cycle and drain is commonly caused by a lid switch. The lid switch is usually mounted under the washer top casing, on the right hand side on most top load models. It is activated by a plastic piece on the lid (called a "Lid Strike") through a small hole on the rim of the wash tub opening. In many cases the lid strike breaks off the lid, or the lid switch becomes loose and no longer makes contact. Inspect the lid to make sure the lid strike is still intact, and then inspect the mounting screws (adjacent to the small opening on the wash tub rim) and make sure they are snug. If you determine the switch to be defective, the following link explains how to replace one:
http://www.fixya.com/support/r385198-replacing_lid_switch
If the switch requires replacement, a new one can be purchased on line at searspartsdirect.com, pcappliancerepair.com, repairclinic.com, appliancepartspros.com. Just use your model number as your search criteria. All these sites offer competitive pricing, so shop all them for the best price.
Let me know if you need further assistance. I hope this helps you.
Why did my washer quit spinning out in spin cycle
Quite often the problem with spin cycles is that the cycle cannot start until a sufficient amount of wash/rinse water has drained. So what will often happen is that the washer drains, the cycle starts, a lot of water comes out of the clothes, it stops, waits for the water to drain, then restarts. If the drain pump or drain lines are restricted or blocked or the pump is faulty, the unit may never achieve spin cycle.
Washer won t fill water
pipes maybe clear but is your area wher you live prone to limescaling? where the water pipe/pipes go into the machine there is a switch to shut on/off the flow of water during whatever cycle you want.this might be blocked or sticking. first try to select different cycles and see if any of those fills the machine with water. if no water comes its one of two things. that switch is faulty or communication between the switch and the front consule is at fault.
contact your supplier after trying to go thru a few different cycles.
12helpful
3answers
Washer not spinning in spin cycle
My maytag neptun mah4000ww washer stop spinning in spin cycle.
Now it stop spin even during regular cleaning cycle. What to do?
How mach it may cost?
3helpful
2answers
Washer won't drain.
My washer fills up with water and goes thru the wash cycle but when it's time to drain, it just sits there and clicks.
Wash doesn't go through full cycle
I have a Maytag model A490 clothes washer. It works fine up to the rinse cycle and then shuts down. When it reaches this point it has become necessary to manually advance the dial a short ways whereupon it will fill with water and complete the rinse and spin cycles. This happens on both the regular and the permanent press cycles. What needs to be done to fix this problem?
Water fills the washer during spin cycle
defective timer...a model # should be under the lid...or open dryer door and on front dryer panel right hand corner..onthejob
2helpful
4answers
check the lid switch on the washer its below where the tab on the washer lid that goes down in the body of the washer there two screws at the base of the control panel back these out and raise the panel you will see a connector coming from the washer disconnect it and put a jumper wire where it goes to the control panel turn it to spin pull out the knob if it spins replace the switch if it doesn't reply to me and we will go from there
4helpful
Check your exit hose spigot, it may be clogged. This is if your filter is all clean. (consult your manual to know where/how filter is cleaned). There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
Rate me pl.....if helped.
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
