Cameras Logo
Posted on Mar 01, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My camera canon power shot sd 1300 is dont work it say error reset automaticalli
Tom Carson
Level 3:
  • Master 3,083 Answers
  • Posted on Mar 01, 2011
Tom Carson
Master
Level 3:
Answers
3083
Questions
0
Helped
683763
Points
8555
You could be having a power problem, or lens issue. The following blogs discuss things you can try to get the camera working:
http://camerarepair.blogspot.com/2007/11/simple-fix-for-dead-cameras-that-wont.html
and:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
If nothing helps, contact a local camera shop to get an estimate for repair, or contact Canon support:
http://www.usa.canon.com/cusa/consumer/standard_display/support
Good luck, and hope this helps.
Como hago para reiniciar una canon power shot sd1300 1s
De acuerdo con la guia de usuario, debes seguir este procedimiento...
Espero que le sea de ayuda.
Sep 04, 2012 • Cameras
Canon power shot SD 1300 IS says" lens error" will shut down automatically
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here are some troubleshooting steps that you can try that may (or may not) correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty (or repair cost approaches that of the camera), they're worth that try. Some of the later steps do involve some risk to the camera, so carefully weigh your options before deciding to conduct them.
2helpful
Don't have software cd for cannon power shot sd 1300 is - ixus 105. where can i find the software for download?
http://www.usa.canon.com/cusa/consumer/products/cameras/digital_cameras/powershot_sd1300_is#DriversAndSoftware
MY CANON POWER SHOT A 80 DONT WORK
Lens errors (E18 errors on Canons) are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
7helpful
Canon Power Shot A400 will only work with original Canon SD card
Make sure you are using an SD card and not an SDHC card. The SDHC protocol is newer than your camera, and your camera does not support it. SD cards have capacities up to 2 GB. Your camera should work properly with any SD or MMC card.
E 18 problem
I dont know what error E18 means, check cannon support for that, but welcome to the world of DISPOSABLE CAMERAS, I have replaced 3 cameras in 3 years, 2 because of lens and shutter issuses.
E 18 problem
E 18 problem
Jan 08, 2009 • Cameras
2answers
E 18 problem
the E18 means the lens system has a problem. I had it with my S2 and sometimes it worked, sometimes not. Eventually it stopped working. The only solution was sending it to repair, they changed the lens system.
Best Regards
Top Cameras Experts
ZJ Limited
ZJ Limited
ADMIN Andrew
ADMIN Andrew
Are you a Camera Expert? Answer questions, earn points and help others
