1) 6 of 7 timers bad sounds very unusual: contact Intermatic:
http://www.intermatic.com/customer%20service.aspx2) Who supplied the timers?
These timers come with limited 1 year warranty.
3) You can wire new timers yourself.
Each one wires the same as electrician installed.
Simply duplicate exactly what the electrician did.
Don't worry, other folks do this themselves every day.
Turn off circuit breaker to each before changing timer.
Take a few minutes and label your breakers while changing timers.
4) ST01C timer is not affected by small ground faults and problems with wiring since it works by battery. So the circuit is not suspect unless Load (light) is located farther than 100' feet from timer, or wiring is underground.
Open following link for ST01C manual, wiring, and step-by-step programming.
http://waterheatertimer.org/ST01C-program.html5) If ST01C timers are located in cold environment, for example a garage or outbuilding, then batteries will only last 20 days or so. ST01C is an interior timer, not an outdoor timer.
Timers that are made for 3-way switching are indoor timers because of internal or replaceable battery.
6) For cold weather timer that can be used for astronomic dawn-to-dusk -or- 7-day 7-program, you can buy Utilitec 0192773 timer at Lowes.
http://waterheatertimer.org/Program-wire-Utilitec-0192773.htmlThis timer wires differently than ST01C, but step by step shows on link above.
I think Intermatic makes the Utilitec timer.
7) For cold weather timer that works 7-day 7-programs, buy GE 15071 at Home Depot (does not have dusk-dawn operation)
Wiring and manual show on link below.
http://waterheatertimer.org/GE-timers-and-manuals.html#15071Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
