Question about Sony VPL HS1 Multimedia Projector
I have a SONY VPL-HS1 projector. I replace the lamp after a "lamp cover blinking signal" I thought that the time of the lamp was over... but besides with the NEW lamp the problem persist. Any idea?
  • 442 Answers
Check the lampm cover and the air filter cover.
either can cause the error message
Posted on Mar 01, 2011
6ya staff
SOURCE:
How to removed Lamp/cover error of Sony VPL-EX5 projector?
Take the lamp cover back off. Check the mechanism that the projector uses to sense the door. It might be a small pressure switch. Check whatever triggers the mechanisms is still attached to the door and hasn't broken off.
Sep 15, 2014 | Sony VPL-EX5 Projector
I have a sony vpl-cs5 but is not turn in on, some body can help me, have a blinking led that say lap/cover.???
That could indicate the following-
1. The lamp cover or filter cover aren't properly closed. Try shutting the projector down> opening both covers> closing them> restart
2. The lamp is nearing the end of its life or is faulty and you'll need to replace it.
May 04, 2011 | Sony VPL CS5 Multimedia Projector
I have Sony Projector XGA VPL FX51 and the COVER LAMP LED is Blinking. Please Guide me to solve it?
check that the cover is secured properly and the little switch inside the init is activated by the plastic protusion on the inside of the cover, when installed correctly
Apr 06, 2011 | Sony VPL-FX51 Multimedia Projector
I have changed the lamp in a Sony VPL EX-1. I have fitted a YODN (LMP - C150) I cannot get the flashing light to go out which indicates `lamp,cover` and I cannot do anything with the projector.
When you open the lamp cover for replacement of lamp there is a switch in the projector is OFF
If lamp cover not fix proper after replacement of lamp the lamp/cover indicator flashing
SOLUTION: Open the lamp cover and fix proper and tight the screw
Feb 22, 2011 | Sony VPL-EX1 Multimedia Projector
Lamp/cover lite is blinking and projector can't start
Remove the lamp and reseat it carefully, following the instructions in the user manual.
If this doesn't help you may find that you need a new lamp.. if you are in the UK you can purchase a Sony VPL-EX5 Lamp here or from here if you are in the USA
Feb 14, 2011 | Sony VPL-EX5 Projector
Sony VPL-CX61 lamp/cover blink. Power on, it
hi,
your projectors lamp cover may be open. or there is some thing happened (may be contact problem) with the lamp cover open sensing switch. just open the door and close it. and then try again.
ok
Dec 20, 2010 | Sony VPL-CX61 LCD Projector
Need asistent
my sony vpl ex3 will not light up, has a lamp/cover light on all the time can somebody help
Jun 21, 2008 | Sony VPL-EX1 Multimedia Projector
Sony vpl-px20
The bulb is faulty. Replace it.
Oct 29, 2007 | Sony VPL PX20 Multimedia Projector
Lamp/Cover Error
I had the same problem with a "Sony VPL-ES3" projector. The lamp cover light would flash and the projector wouldn't turn on.
I think its a problem with a filter cover. This fixed the problem for me:
  1. Plug out the projector
  2. Click off the filter at the bottom of the projector.
  3. Plug the projector back in. (the lamp cover light should flash)
  4. Plug the projector out again.
  5. Put the filter cover back on.
  6. Plug the projector in again and it should work fine.
This has worked for me every time I have had this problem.
Sep 29, 2007 | Sony VPL-ES3 Multimedia Projector
Sony VPL HS1 Multimedia Projector Logo
446 people viewed this question
Top Sony Office Equipment & Supplies Experts
jasbo
jasbo
Eric Rotmil
Eric Rotmil
Are you a Sony Office Equipment and Supply Expert? Answer questions, earn points and help others
