The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
SOURCE: Olympus Fe-280
this still doesnt help me
please i need to clearmy camera rgently
as i am going to the gold coast
SOURCE: olympus FE-230 - will not import certain video to computer
Make sure your not running the cable through a hub of any kind.
Plug it directly into a usb port on the computer.
Sometimes the hub can limit the bandwidth (speed)
and with video you need all you can get.
I'm assuming here that your computer is new enough to have the
2.0 usb standard.
Best of luck Paul
SOURCE: Write Protect error and I think all my pics dissapeared!
If you are using an SD card, it could be possible that the Write Protect tab (the yellow tab on the top right) is in the 'lock' position. Slide it back and try again. If this does not work, make sure you are using the card and not the internal memory to store images.
SOURCE: memory card cannot read by digital camera.
Sounds like you will need to format the memory card. This will permanently erase all the data from the card and then you will be able to use it again. To format the card: Press the Menu button - right arrow to Setup - go to format option- You will see format yes or no. Choose Yes and press ok. This will clear the write protect message and the card can be used again.
SOURCE: xD CARD Terminal
hi i have the same problem at the moment
i was wondering if anyone has found a solution yet to fix it without losing the photos. your help would be greatly appreciated, thanks
