Try resetting it to factory defaults. Consult the manual for specifics. Usually, you unplug the router, hold the reset button, plug it back in, and then release the reset button after about 60 seconds, but it could be different for this particular model. Who configured your network previously? You or someone else?
Hello! When you say that you're trying to use the router and it doesn't work, what specifically are you having a problem with? Is the device having problems powering up, or is it simply failing to send traffic back and forth? Have there been any other changes in the network since you last successfully used the router; i.e. a change in Internet Service Provider?
Thank you!
