From your main/home screen :
1. Press your "Menu" button. ( located near the bottom of your phone to the left of your home button )
2. Press the "Settings" button.
3. Press the "Wireless and Networks" button.
4. Check the Bluetooth box to turn on bluetooth.
5. Press the Bluetooth Settings button.
6. Put your Jawbone Icon into discoverable mode. Follow this link for instructions if you cant find your manual.
http://www.headsets.com/headsets/resources/jawbone-pairing-guide.html
7. Click "Scan for Devices" on your EVO.
8. When your Jawbone Icon appears in the Devices list click on it and pair the devices. At this point it will ask you to accept pairing. Once you do that you should be good to use your headset.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/thomas_e8f475a8655f7b4a
For Jawbone ICON, while the power is off, press and hold down the Talk button and slide the power switch on. When the LED starts to flash red and white alternately, release the Talk button.
1. Press the OK Key.
2. Highlight SETTINGS & TOOLS and press the OK Key.
3. Select Bluetooth Menu.
4. Select Add New Device. (If Bluetooth power is set to off, you will be prompted to turn power on. Select Yes and press the OK key.)
5. Highlight Jawbone and press the OK Key.
Enter the PIN "0000" (be sure to enter four zeroes and not the letter "O") and press the OK Key.
