Sounds like the top thread is under too much tension, check the threading trail from the spool to the needle for anything not threaded correctly or snagging the thread. Do you have an aerial arm to take the thread through above the thread spool, and if so, is it extended? Is the thread catching on the thread spool label or some part of the spool as its coming off, they often have a little nick to catch the loose thread end and if the thread catches in this during sewing the thread will snap. Now check the tension discs, turn to zero and clean between the discs by running the edge of a piece of waste thread through them. Now rethread, set tension to the normal number you are used to and try again.
Is your needle in the right way, flat shank to the back. Change to new needle and try again.
If thread is still breaking, I'd visit a serviceman.
Testimonial: "Sounds like good advice; knows what she's talking about."
Thanks for the help. I emailed my service guy asking if I can get into the tension and get it cleaned out myself; if not, it probably needs a good cleaning out anyway. It's definitely not a spool issue- I learned that early on and generally just put in the vertical pin and let the spool unwind off that to avoid that problem. Hope cleaning the tension works.
Apologies for TYPO above, ...."Clean between the discs by running the selvage edge of a clean piece of cotton fabric scrap through them...."
