If you have forgotten your pass code them you need to go to the Xbox 360 Dashboard, go to the system area, then to family settings, then console control and enter an INCORRECT pass code. You will be informed that your password is incorrect and there should be an option to reset your pass code. Press that and you will then have to answer your passcode question. If you answer this correctly then you will be able to set another pass code.
If you have forgotten the answer to your question then you will have to contact Xbox Customer Support im afraid. Hope this helps!
Try this
System Blade/console settings/system info screen,
then this key combination
LT, RT, X, Y, LB, RB
or in the same console screen try this X,L,X,Y - but it should reset the console to initial settings (factory settings).
if none ot these work you can contract Microsoft directly and they can unlock it if you are registered online with the xbox.
I NEED YOCASH NOW!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
SOURCE: i forgot my family settings
Reset a Forgotten Pass Code
To reset your Family Settings pass code after you've forgotten it:
Type your answer using the on-screen virtual keyboard and either your Xbox 360 controller or a standard USB computer keyboard plugged into a controller port on your console. Your answer is case-sensitive and must be typed exactly as you entered it originally. This will clear your original pass code and allow you to enter another.
I forgot my Pass code for my family lock and I can't remember my question.
