It doesn't need to be specific to the model, most epilators can be cleaned in the same way, this guide is great for giving you tips on the best ways to clean. How to Clean Your Epilator Our Guide The Best Epilators
AFTER EACH USE
CLEANING THE EPILATION HEAD
Ensure the epilator is turned off and disconnected from the mains.
Press the head release button/s and open the head assembly. (Diagram G)
Turn the head assembly upside down.
Using your thumbs, push the small sides together and push the epilation head upwards. This releases the
curved epilation head.
Brush the accumulated hair from the tweezers by turning the barrel manually.
NOTE: The body of the epilator is not washable. Do not submerge in water.
TO REMOVE RESIDUE
To remove residue from the stainless steel tweezers, dampen a swab with alcohol. Gently run the swab over the tweezers until the residue has been removed.
Online Manual: http://uk.remington-europe.com/pdf/ep6010_user_manual.pdf
