Most likely the float has become stuck in the closed position.
Check to make sure fuel is still running out of the petcock
Open the drain on the Carb (should be located near the bottom) turn on the petcock. Fuel should flow from the drain freely. If not then the float needle is either jammed or some thing else is inside the carb stopping fuel from flowing into the bowl.
