SOURCE: whirlpool pin retainer is broken on ice dispenser
You don't have to replace the whole door. There is a kit that comes with instuctions. You can get it at www3.sears.com and the part # is 2206423 and switches over to #8201649 and is called door mechanism assembly. It is $42.99. Use # 2206423 for lookup purposes. Hope this helps.
SOURCE: Whirlpool side-by-side refrigerator ice dispenser
First pull out the ice bucket and close the door. Set for cubed ice. Press the button for ice to come out and listen for a loud clunk noise. That is the sound of the solenoid. You can open the door, hold the light switch and press the button and watch for the solenoid moving up and down. Solenoid is at the back of the freezer in a little square opening where the rod on the ice bucket goes into. If that solenoid is moving ok then put the bucket back in while the solenoid is in the down position and cubes should work. If solenoid is not working then it will need to be replaced. Let me know what you find.
SOURCE: Whirlpool refrigerator ice dispenser
The front cover is snapped on. There should be two slots in the bottom of the cover. Put a wide screw driver in the slots one at a time and pry out. It snaps off very hard.
SOURCE: whirlpool refrigerator ice dispenser no longer workds
Ok, I show parts that are available for that model, sounds like the control board is defective for your dispenser, or possibly the Ice maker control board. It also could be a break in the wiring or the control itself. Below is a break down for those parts, wiring and the control behind the push to dispense ice or water. Hope it is not that control because some places don't provide that part. Now if it's a connection problem that we can find, I will do mu best to help you solve this.Could you insure the model number is correct as this is very important? [email protected]
SOURCE: my whirlpool refrigerator ice maker does not make
I have a whirpool side by side ref with ice and water in the door. I'm getting water but no ice, I can't find my modle#.
