That means there isn't much memory left. You will have to delete some applications:
The uninstall processes on LG Incite mobile phone are not complicated, three ways you can choose below according to situation/setup. LG Phone Problem and solution
1. Uninstall Apps Using ActiveSync LG-Incite info
For Windows XP and below users will want to use the ActiveSync program. You can download ActiveSync 4.5 here.
Once downloaded and installed on your desktop ActiveSync uninstalls are one of the easiest ways to remove unwanted programs, simply follow the directions below:
It's really that simple, your LG Incite will take a moment to uninstall the unwanted Windows Mobile Apps you chose and then you're done.
2. Uninstall Apps Using Windows Mobile Device Center
If
you're a Windows Vista desktop user there's no reason to download
ActiveSync, partly because it won't work, but more importantly because
Windows Vista comes standard with the Windows Mobile Device Center, a
device to desktop sync application that functions in much the same way
as ActiveSync 4.5.
Uninstalling Apps with Windows Mobile Device Center is a simple process if you follow the quick steps below:
The unchecked programs will now uninstall from your device, its really that simple.
3. Uninstall Programs Directly From Your Windows Mobile Device.
You don't have to use a computer to delete programs from your LG Incite, if you're on the go uninstalling apps directly from your system once again involves only a few quick steps.
Your LG Incite will now remove the highlighted application.
Personally I usually use my computer for deleting apps just in case anything goes wrong during the uninstall process, however i've rarely heard of people running into Windows Mobile uninstall issues when doing so from their devices.
Conclusion
The 3 uninstall options listed above are the easiest ways to uninstall apps from your Windows Mobile based Pocket PC and Smartphone devices.
If
these steps don't work your best bet may be to use the "Clear Storage"
option on your Windows Mobile device and start your device with the
standard fresh install, but hopefully it doesn't come to that."
