Hi
Find the indication light, located at the top of the Whirlpool
refrigerator just inside the door. This tells you when to change your water
filter. A green light indicates the filter is good and a red light indicates
you need to change the filter.
Find the filter knob. It is usually located at the base of the
refrigerator in the kick plate or grill.
Turn the knob a quarter turn to the left to unlock the filter.
Pull out and remove the old filter.
Add a new filter and push in. Turn the filter a quarter turn to
the right to secure it in place.
Reset your filter indication light inside the refrigerator. Press
down and release the switch five times within 10 seconds. The filter indication
light should then turn green.
Please get back to us if you have further query or else please accept the solution.
Thanks for contacting fixya.com
Reset Filter (select models)
When a water filter has been installed in the
refrigerator, the yellow Order light will illuminate when
90 percent of the volume of water for which the filter is
rated has passed through the filter OR 11 months have
elapsed since the filter has been installed.
The red Replace light will illuminate when the rated
volume of water has passed through the filter OR 12
months have elapsed since the filter was installed. A
new filter should be installed immediately when the
Replace light is illuminated.
After replacing the filter, press and hold the Reset
Filter pad for three seconds. The Order and Replace
lights will go off.
Vacation Mode
The Vacation Mode feature causes the freezer
to defrost less frequently, conserving energy. The
Vacation Mode indicator light will illuminate when the
feature is activated. To deactivate, press the Vacation
Mode pad again OR open either door. The indicator
light will go off.
Temp Alarm
The defrost is not working and the fan is hitting ice buildup...
Check
out these tips...they can help you figure out what is going wrong
with your refrigerator
Refrigerator
not Cooling
or Fridge not Cooling
How to Defrost Refrigerator Defrost
Timer Problem
Water
Running in refrigerator
from Freezer
Refrigerator
or Freezer not Cooling or Getting Cold
heatman101
