Canon PowerShot SD400 / IXUS 50 Digital Camera Logo
Posted on Feb 27, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I bought a new battery for my canon ixus 50 but it is still showing low battery. Also, i cannot transfer photos to my pc. How do I solve these issues?
Anonymous
Level 2:
Scholar:
  • Expert 57 Answers
  • Posted on Feb 28, 2011
Anonymous
Expert
Level 2:
Scholar:
Answers
57
Questions
Helped
13873
Points
144
For the photo transfer, remove the memory card from the camera and insert it into a memory card reader. Some PCs have these build in. If not, you can get one from any electronics store. The card readers plug into your PC's USB slot and the card shows up as a drive on the PC. You can copy & paste (or drag & drop - your preference) to move the pictures from the memory card to your PC.
For the battery - did you charge it before use? Most batteries ship at about 30 to 50% capacity.
Low battery showing replacing batteries does not solve problem
The flashing low battery symbol is the way Canon film cameras showed that the camera has had an error and has stopped functioning. It can have multiple causes - but for a quick check remove the lens, turn off the camera and then turn it back on - see if the symbol stops flashing. A problem with the lens can also cause this problem (usually a failure of the aperture unit)
Brand new battery won't hold charge. Camera is three years old. I bought an extra battery when I bought the camera. They both seemed to go bad at the same time, so I recently bought two new lithium...
if this happens even to new batteries, it may no longer be an issue with the batteries, but it can be an issue with the camera itself. check the maximum number of shots that the camera can take with the batteries per its specification. if it should produce more, it would be a good ide ato check with Canon to have the camera checked.
2helpful
Canon PowerShot A480 won't take photo. Pressing on button camera on then pressing silver button to take photo when pressed down screen turns black no picture taken. Batteries new. This is the story; camera...
its just a matter of batteries...some are not powerful enough to operate the camera ....Try to change them and buy some real good ones..like Duracell or Tatra...do not make any compromises when buy the batteries...get the best cause these kinda cameras really require powerful ones...or ...try to get a set of rechargeable ...
2answers
I have a Canon Ixus 60 and the low battery indicator flashes most of the time - even on a fully charged battery. Is my camera destined for the graveyard?
No, but the battery may be ready to be buried. The rechargeable battery is only meant to last a couple years maximum, then should be replaced. If the age of the battery is about the same as the camera, then this is your likely problem. Fortunately, there are many inexpensive generic alternatives for your battery these days. Here are some from Amazon. Performance varies among the generics, so make sure you read the user reviews before purchasing.
Transferring large video files from Canon IXUS 80IS
my friend, i encountered the same problem as you are, but as i see there is still no solution in this problem.. have you overcome the problem? can you teach me how... need this files badly... thanks amiya23..
2helpful
Photos from Ixus 100 won't display on laptop after transfer - may be a problem with the SDHC card? Can see pics on camera but not on computer - other sdhc card transferred without a problem
This is often down to a lack of battery power - check the charge level.  Level may be OK for the moment of time you need to take a pic, but will not support a long transfer operation.
Its always best to use a card-reader. If the computer can "see" the card, then any photo-program should read the card.
Canon ixus 50 unable to delete photos from card
If the card is a removable memory card, take it out and use a adapter on your computer.  Format the card on your computer then put it back into your camera.  It should be ok after formatting on PC.
Tranfering pictures
use the usb cable, the pc will see it as an external drive, pics will be in the dcim folder
Powershot sd 400
have same problem with canon sd10. bought new battery and new charger, THIS IS A CANON HARDWARE PROBLEM I assure you
3helpful
4answers
Unidentified images
I have the same problem with my Canon Powershot SX110IS. images dissapear with the notation "unidentified image". I brought my camera in to a local camera shop, and they were able to save the lost images. They told me I had an inexpensive, low quality memory card that is causing this problem. I upgraded to a high quality one and haven't had the problem since.
Top Canon Cameras Experts
old marine
old marine
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Canon Camera Expert? Answer questions, earn points and help others
