Maybe the pump has failed? How did you drain it? If it was through the outlet hose then I assume that the hose is clear You should be able to hear the pump working when you start it.
Does the message appear immediately or after a while?
DRAIN PUMP FOULTY
This is a very common issue on Bosch dishwashers. You can clean the pump from the inside of the unit. The link below is a video that explains how to do so.
Bosch Dishwasher Repair Video
Appliance & Refrigeration Repair
Here
is a tip that I wrote that will help you with your dishwasher not
draining problem...
Dishwasher Problems - Water
will not drain
out
heatman101
