Hi, I am one of the technician trained and specialized in different computer and printer manufacturer. Here is one of the instruction on how to install your printer to windows 7 64 bit -run the driver downloaded from the site, then select the location for Standard TCP/IP port has already been created on the computer, choose the port from the Use an Existing Port pull-down menu, next, and then skip to step 10. For the port has not been created on the computer, choose the create new port button, choose standard TCP/IP from the Type of Port pull-down menu, click Next, and then continue with step 8. -put the IP Address or hostname of the printer for more information visit: Contact number: English 1-800-821-2797 I hope this will help a lot. thank you for choosing Fixya
-Go to Control panel
-choose devices and printers
-add a printer
-add a local printer
-check if the query for printer is set to automatic, then next
-choose have disk
-choose browse, then select where you save the driver
-choose the required printer model
confirm the name of the printer
-choose do not share, then next
-choose finish
Spanish 1-800-821-7726
Hours of Support - 24 x 7
Guys who need windows key can go link http://cheapwin7activationkey.tumblr.com to got. My key got here and after i used is great works. Hope help you.
