To enjoy sound from the TV (Page 29)
AUX*1: When using an Audio cable
ARC*1: When using an HDMI cable
(Available when using an ARC
compatible TV)
DIGITAL IN*1: When using an Optical
digital audio cable
And from Page 29
Turn on your TV and select the appropriate audio input mode
[AUX, ARC, D-IN] to suit the connections to this unit. (Page 22)
Page 30 details how to set the audio link.
Setting the audio link with the TV
With the remote control;
Select the actual TV audio connection on the main unit.
1 Press [START] and press [3, 4] to select "Other
Functions" and press [OK].
2 Press [3, 4] to select "Setup" and press [OK].
3 Press [3, 4] to select "TV / Device Connection" and press
[OK].
4 Press [3, 4] to select "TV Audio Input".
5 Press [2, 1] to switch "AUX","ARC" or "DIGITAL IN".
Select "AUX" or "ARC"*1 in "TV Audio Input" when the
DIGITAL AUDIO IN terminal is used for the STB
connection.
Whenever the connection or settings are changed, reconfirm
the points above.
Please leave feedback
Cheers
Andy
Basic steps to check if the problem lies with the home theatre system or not.
1. First thought might be to conclude that your poor audio quality is caused by your speakers, before you immediately race out to purchase a new home theater surround sound speaker package, check the basic things first.
2. The problem might not be in the speakers, but in the amplifier or the connections from the amplifier. Checking and ensuring that the speakers are correctly connected on both ends is the first step.
3. After the connections pass examination, the next step is to check if the problem lies with the amplifier or audio speaker. Some of the lower end home theater systems come with low powered amps. Most often they do not supply sufficient power to speakers to produce the quality audio you desire. This may show up particularly if the room is large when the sound doesn't fill up the room.
4. To determine if it is indeed the amplifiers then hook up your speakers to a stereo; this generally will have a more powerful amp. If the speaker quality improves then the problem probably lies in your home theater amplifier.
If you cannot distinguish any difference, then your speakers could possibly be at fault.
5. Poor cable installation and audio speaker cable are another possible cause for consideration. Cheap workmanship can lower audio quality and home theater packages often come equipped with inexpensive poor quality cables.
6. If you experience problems with your theater system, it is always best to assume the problem lies in the connections between components first and then suspect the components themselves.
7. To ensure a great sound experience ensures that everything is properly connected, your amp is of sufficient power, and the cables are of high quality. If a person makes use of these basic easy precautions a significant amount of frustration can be eliminated. If your home theater sound isn't where you need it to be, use those hints as a blueprint as you analyze your system. If it really is time to look for new components, consider those directives as you make your next purchase.
Note : Check to see if the color is bad across all input sources. If so, make sure you have your Televisions' color settings set to your preferences. If everything looks good except, say, your DVD player, and it is connected to your TV via Component Video Connections (which is composed of three cables - Red, Green, and Blue), make sure they are matched up correctly with the Component (Red, Green, and Blue) connections on your TV. This is a common mistake as it is sometimes hard to distinguish the Green and Blue connectors if the lighting in the connection area is dim.
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/Panasonic-SC-BTT350-Home-Theater-Systems-manual/id/23826dj494/t/2/
If it has no obvios way to change its input voltage to 220V on the back, no.
