SOURCE: ibook G4 14" 1.4mhz
On an Apple system, this is an indication that it thinks there is little or no battery left and goes to sleep to protect data loss. Your battery might be going bad (showing a full charge, but lasting for only a few minutes) or there may be a problem with your power supply.
SOURCE: ibook g4 12" 800mghz freezes alot, especially when bairly moved
Hi Robert
Try a reset of the PMU, instructions here:
http://support.apple.com/kb/HT1431?viewlocale=en_US
All the best
Sean
PiDigital
SOURCE: apple ibook g4 ejects every movie i put in and will not play
Reinstall the operating system.
SOURCE: ibook g4 freezes and airport problem
have you gone into airport utility?
are you using an airport extreme? if so, reset it.
then delete the current wireless network, and try setting up a new one in airport utility.
SOURCE: during start up my ibook g4 freezes at the blue
The blue screen marks the start of the login process. If the Mac freezes there, it usually indicates that some third-party System Preference is hanging the boot process. There are several ways to diagnose the problem. The simplest is to hold down the Shift key after hearing the boot chime. This will disable third-party System Preferences and should allow you to come up to the login screen. Then you can review the third-party preferences and go to the website of each of them to make sure you have the most up-to-date version that is compatible with your level of the Mac OS.
