Whirlpool GGQ8831L Gas Dryer Logo
Posted on Feb 26, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Had no heat. replaced thermostat, heat returned for 15 minutes, then no heat again.
Tim Whalen
Level 3:
  • Master 3,076 Answers
  • Posted on Feb 27, 2011
Tim Whalen
Master
Level 3:
Answers
3076
Questions
0
Helped
824440
Points
9577
This website will help, more then likely you will need to clean the venting system and replace all the recommended parts for your dryer:
http://www.applianceaid.com/gas_dryer.html#noheat
Replaced thermostat and engine coolant sensor and car is still over heating
I think you have a leaking head gasket, this causes the symptoms you have.
After a cold start, I don't get cabin heat for about 15 minutes. The heat gauge starts at C (cold), rises to normal operating temperature, then rises to just under the H (hot) for about 30 seconds, at...
Check for low coolant, you might also have a sticking thermostat. Alot of fords get air pockets, make sure if it needs coolant to let it run for about 10-15 min with the radiator cap off.
I have a new trane system - thermostat makes an annoying clicking sound every 10-15 minutes -
Sorry to say, that annoying clicking sound is the thermostat calling for cooling/heat. Whenever the temperature is reached it will "click" off and then "click" back on when needed. Some thermostats are quieter, but all digital thermostats will have that sound. Sorry again and I hope this answers your question!
Whirlpool estate electric dryer model teds680eq1 starts spins heats up then quits 15 minutes later
The operating thermostat has probably failed. When the dryer haets up, it gets too hot and the high limit thermostat turns the machine off. After it cools down, it will start, again.
2helpful
Dryer shuts off after 15 minutes and needs to cool down then will start again and the cylec continues!!On, off,on, off.
The problem is more likely a high temp limit switch. I don't have a schematic of your dryer, but one should be included somewhere on the dryer. You have to use a voltmeter to test the components in the circuit. The thermostat controls the heat temp, you may want to start there
Dryer runs for 15 minutes and stops
check the in-line limiters on the heating coil tube.
1helpful
Manual or directions
We have the same model. From the manual:
STEP 1: Slide the system switch to the HEAT or COOL position to program the corresponding system
STEP 2: Press PROGRAM to enter program mode. Heat or cool will be displayed on the LCD.
STEP 3: Press the UP or DOWN arrow. The Program hour and AM or PM indicator are flashing. Press to change the hour.
STEP 4: Press PROGRAM to change to the minute position. The current minute will be flashing. Press the UP or DOWN arrow to change the minute.
STEP 5: Press PROGRAM to change to the program temperature. The current temperature will be flashing. Press the UP or DOWN arrow to change the temperature.
STEP 6: Press PROGRAM again to move to the next program number. Repeat Steps 3-5 to change the remaining Weekday and Weekend Programs. [there are a total of 8 programs]
After cycling through all 8 programs, press PROGRAM again to return the display to normal. Press HOLD/RET at any time to exit the Program Mode.
TEMPORARY MANUAL OVERRIDE:
To temporarily change the current set temperature without affecting your program:
  • Press either ARROW and hold for about 1 second to enter the Manual Override Mode. When display flashes, you can release the key.
  • Press the ARROW to change to your desired Temperature
  • Press HOLD/RET to return to normal mode, or wait 15 sections for it to return automatically.
  • The current program number will flash to signify the Temporary Overide.
  • At the next program change time, the Temporary Override is cancelled, and the next program temperature becomes the setpoint temperature.
Hope this is what you need. God Bless.
Dryer no Heat. New Thermostat Burnt Out.
sounds like you are replacing the hi limit thermostat try replacing it with the cycling thermostat as well
2answers
Oven cuts out after ten minutes and comes back after cooling down.
We have the same problem with our oven, AEG B2190-1.It started on on Christmas day[worst day of year]gets up to temperature after 10-15 minutes cuts out everything switches off until the oven has cooled down, The oven is only 18 months old. We have been told that it is a thermostat problem.
Top Whirlpool Dryers Experts
Virgil Watts
Paul Bade
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
