Theres a fan/compressor relay inside the case one side operates the fan and the other the compressor,if the fan side contacts weld themselves the relay cannot cycle and the fan will not shut off,remove the wire from the relay to the fan and see if this kills the fan,but dont leave it this way as the compressor needs the fan for air circulation while operating
Thank you for your post, friend!
I see that your question is if the fan should shut off once it has reached the recommended setting. The fan will run even when the compressor cuts off so that air can pass over the sensor coils to check the humidity. This is a normal operation. I hope this is helpful. -Matt
