Epson Perfection V200 Flatbed Scanner Logo
Posted on Feb 26, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I am scanning Kodachrome Transparency's and I am struggling to capture the full image on some slides. Some are scanning fine, others are chopping off an edge? Any ideas?
W.L.
Level 3:
  • Master 2,511 Answers
  • Posted on Feb 26, 2011
W.L.
Master
Level 3:
Answers
2511
Questions
Helped
523868
Points
8345
There are manual position settings you can use.
Make sure the film is placed correctly in the film holder and the film holder is properly
positioned on the document table.
Switch to Home Mode or Professional Mode, and preview with the Normal Preview. In the
Preview window, create marquees on the area you want to scan, and then scan.
Also...if all else fails
Try rotating the slide 90 degrees, you can always rotate the saved image afterwards.Ditto flipping over to the other side
.I hope I have been of help but please do not hesitate to ask if you have any further questions.
I appreciate your vote if you appreciate my reply.
6helpful
Can HP psc 1410 PRINTER SCAN NEGATIVE AND SLIDES
Chances are that somewhere in your family photo collections you have a bunch of slides and negatives that you wish you could do more with. You may want to include them in your family history, to publish them on the Web, or simply to make digital copies so you can share them with the family.
If you've ever tried to scan a negative or slide on a regular flatbed scanner, you'll know that it doesn't work, and you end up with a pure black scan. In this article we'll show you how you get your negatives and slides into digital format, and what issues you may face along the way.
pixblue.gif Benefits Of Scanning Film
There are some key benefits to scanning film (we'll use the term to include slides and negatives) in comparison to scanning a photo. When you scan film, you can use the full area of the slide or negative, whereas a photo will generally only display a cropped portion of the original. You are also scanning the original source image rather than the color corrected and tweaked version of it that the photo processor has provided you with. The process of turning a negative image into a positive one involves inverting the colors in the image and removing the orange cast from the negative. This would be a complicated process if you were doing it by hand; however, your scanner will provide you with software to do this automatically, or you can purchase standalone software to do it.
Most cheaper flatbed scanners are designed to scan photos and other images that reflect light when it is shone onto them. The problem is that film is transparent and light passes through it rather than being reflected off it. Many flatbed scanners have an optional transparency adapter, which replaces the scanner lid with a larger box shaped ob....
Unsharp scans
Sometimes this is caused by scanning a Kodachrome or thick emulsion slide on the "Positive" setting. Set it to Kodachrome and try again.
Sometimes this is caused by dust on the reflector mirror. I know it was a big problem here.
Ifyour scanner is under warranty, you can ship it in to have itcleaned to their service center, or if not, you can give it a shot yourself. Iwould only do this if you are a mechanically inclined person and arewilling to do it RIGHT. Here's a link to instructions:
http://www.pearsonimaging.com/articles/howto/ls5000cleaning.html
Irecommend reading through it at least once before beginning, and makesure you've got the materials you need on hand as well as a cleanworkspace. It worked on our machines. I give them a once over every so often to keep them sharp.
Bryan Clark
DVD Your Memories
Slide Scanning Specialists
3helpful
Can i scan slides with my Canon PIXMA MP150
No. This feature requires a light source to shine light through a slide to the lens so the image can be copied. Your Canon all in one doesn't have a transparency top that shines light through a slide. I had to get an Epson Perfectin scanner with transparency top to copy my slides. Hope this helps.
Funky look to images
Hi folks. I am the originator and have the solution to the problem. I feel a little stupid because I overlooked using a plastic insert/guide which is placed on the scanner, fitting on notches. It lets the scanner know to use the transparency device and provides a notch for film holder placement. It has been so long time since I used film ever since digital photography took over, I overlooked using this plastic insert. With it placed, I can scan film fine. Thanks
2helpful
2answers
Scanning neg
Please do the following to scan slides or negatives in manual mode of the Epson TWAIN:
For scanning transparencies in HOME mode - for EPSON SCAN models, not Epson Twain/Manual mode models.
1) In the program you are working from, begin the scanning process. If working in FULL AUTO MODE as the scan begins click PAUSE or CANCEL, then change "Full Auto Mode" to "Home Mode".
2) You will now see all Epson Scan settings displayed. If the scanner has not previewed automatically, click the large preview button to get a visual of what is on the scanner.
3) Ensure the settings on the Epson Scan are correct for what you wish to scan. For example, the DOCUMENT TYPE for transparencies must be either "Color negative film", "B&W Negative Film" or "Positive film"*.
* FILM here indicates that the item being scanned is transparent to light; this setting is also used for slide scanning. Positive indicates that the image is in true colors (ie the grass is green and sky is blue), whereas negative indicates reversed colors, as produced in some photo finishing processes.)
If the DOCUMENT SOURCE is set for a flatbed related option, ie PHOTO, the scanner is looking for reflective items and will not activate the backlight in the transparency unit. If the DOCUMENT TYPES for "FILM" are greyed out or cannot be selected, close the Epson Scan, reseat the power/communication cable connecting the base of the scanner to the transparency unit, then reopen Epson Scan and try again.
NOTE for PROFESSIONAL MODE users: DOCUMENT TYPE should read TRANSPARENCY for film scans.
4) Ensure the other scanner settings are correct for the type of scan you are doing. For example:
IMAGE TYPE should be color photo for all positive or negative color transparencies, or BLACK AND WHITE PHOTO for monochrome transparencies.
DESTINATION is unimportant, however you should select a RESOLUTION appropriate to what you plan to do with the scans. (There are no hard and fast rules for DPI. As a general guideline, if you are saving scans at original size, a resolution ranging from 400-600 DPI should capture enough information to faithfully record the image. If the slide or negative will be enlarged, you will need to increase this DPI accordingly. We have no means to calculate what your exact needs will be in this situation; you will need to experiment and view the output to gauge the appropriate input DPI from the scanner.)
PREVIEW. If your scanner is doing a THUMBNAIL PREVIEW, the slides will automatically preview and appear in boxes on the left side. Here, you can select or deselect the slides you wish to scan.
If you recieve a message that the scanner could not find the film, or you see in the preview that part of the scan is cut off, click the down arrow next to the large PREVIEW button and click NORMAL, then PREVIEW again. In NORMAL PREVIEW mode, the scanner will capture all information on the flatbed; you will then have to manually marquee or crop the slides you wish to scan. Use the left mouse button (click, hold, drag) to lasso one slide inside a box made of dotted lines, then click scan. Only the selected area will scan. Repeat this process for as many slides or filmstrips are on the bed.
5) Click CLOSE once scanning is complete. The images will now transfer to the application in use.
1helpful
Epson 3490 does not find the slide I put in the correctly positioned provided frame
Scanner incorrectly reads frame position on film
Yes there is
3helpful
Epson perfection 4990 photo scanner
2helpful
3answers
Scanner wont scan transparencies properly
I have the same problem with my 4990. This began when I moved to a new computer running Vista. I've updated all drivers to the latest version including Epson Scan for Vista but the only thing the 4990 "sees" is reflective documents. Negatives are not recognized at all. I know this is probably a different problem from what you are having but the effect is the same.
3helpful
2answers
35mm Color Slides
Here they are for Mac and PC
If you receive a message that the scanner could not find the film, or you see in the preview that part of the scan is cut off, click the down arrow next to the large PREVIEW button and click NORMAL, then PREVIEW again. In NORMAL PREVIEW mode, the scanner will capture all information on the flatbed; you will then have to manually marquee or crop the slides you wish to scan. Use the left mouse button (click, hold, drag) to lasso one slide inside a box made of dotted lines, then click scan. Only the selected area will scan. Repeat this process for as many slides or filmstrips are on the bed.
Top Epson Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
NH TECH
Level 1 Expert
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
