Ovens Logo
Anonymous Posted on Dec 29, 2017
Have a Magic Chef MCO165UW over range. Only 2 old. While heating up potatoes (5 min), it died. It has no display or built in light below. Does it have a in-line fuse? Its inexpensive model, but if its an easy fix, will do, just a pain in the **** to pull out so only want to do once. Thanks for your help! Dan
Melissa Martin
Level 3:
Master:
  • Magic Chef Master 753 Answers
  • Posted on Jan 01, 2018
Melissa Martin
Magic Chef Master
Level 3:
Master:
Answers
753
Questions
0
Helped
196059
Points
1330
There is a fuse. It is on the noise filter under the outside cabinet. You would have to remove it, however, with that being said. Do not touch the capacitor if you remove the cabinet as it can kill you if you do not know what you are doing. Make sure you unplug it from its power source and wait 10 minutes or more before entering the interior. You can buy just a fuse , it is a ceramic 250 volt 20 amp fuse. Magic chef wants you to buy the noise filter with the fuse on it, part number 3518608000. Please be so careful about this, it is no joke the capacitor can kill you. Good luck and again be careful.
5 Related Answers
Dave Harrison
  • 114 Answers
  • Posted on Sep 27, 2007
SOURCE: Magic Chef Oven won't light
Your oven bake ignitor is becoming defective. Even though it is glowing, the resistance is not great enough to "pop" the gas valve open and is slowly seeping gas into the oven cavity. With a strong ignitor, the oven should light within 30-45 seconds. Because this is a gas oven, I DO NOT RECOMMEND FIXING IT YOURSELF. Call an experienced technician.
Philip Markert
  • 165 Answers
  • Posted on Apr 24, 2008
SOURCE: Magic Chef range
Ignitor is very fragile and may have cracked.
Anonymous
  • Posted on May 14, 2008
SOURCE: "F1" error code on Magic Chef gas range Model 3488XRA
the burners on my magic chef stove work but the flame is not as high as it should be on one burner. I switched the top of the burner with another and it did not solve the problem.
lsteward68
Raymond Ramirez
  • 333 Answers
  • Posted on Apr 27, 2009
SOURCE: We own a 1973 TravelEze travel trailer with a magic chef lp 4 burner range. The model number is unreadable. It does start with BT22 we think. We would like to order a replacement gas regulator and a m
I think you should have more numbers. there are quite a few other series for this unit. I have posted a site below for your assistance.
http://www.aaarv.net/bt22_series_parts.htm
Please rank if this helped
matlock_mich
  • 77 Answers
  • Posted on Nov 17, 2009
SOURCE: how do I troubleshoot my Magic Chef electric built
Hi,look in the control console for the tech sheet or under the top of the unit.A good place to start.Hope this helped.
Magic Chef oven displays F3 everytime the bake or broil button is pushed. Not sure what the model # is. Electrical range.
this could be a an open probe or shorted probe connection.you need to check your temp probe harness to your main board.
there is a chance that you need to replace your temp probe.
last thing would be to replace the EOC
Range won't heat up
it is a glow coil , thermocouples are on units with a free standing pilot that you have to light, if you have a range like this you may need a thermocouple if not a free standing pilot you have a electronic gas iginition system that uses a glow coil, you turn on over setting and oven glows orange then iginites if this is what you have you need new glow coil, easy to repalce
No power to Magic Chef Electric oven
I'm not familiar with this oven, but it ought to have protection against this kind of exciting burn-out.
This could be a fuse: find it and replace it, or it could be a circuit breaker: look for a reset button.
As I said, I don't know this oven; this attempt to help is based on the general idea that it ought to have some built in protection.
How do I troubleshoot my Magic Chef electric built
Nov 17, 2009 • Ovens
1helpful
2answers
Magic chef oven/stove top range not staying hot
Hi, It very well could be the ignitor. Sometimes they work at first and then will not open the gas valve later in cycle. You can set the oven to heat and watch the ignitor. If it glows and the gas will not ignite in 30 to 45 seconds, the igniter is getting weak. I jope this helps.
Please let me know if I can assit you further.
Vic
Wont Heat at all
sounds like you have a bad wire connection someplace in the oven.
Top Magic Chef Ovens Experts
ZJ Limited
ZJ Limited
vince
Are you a Magic Chef Oven Expert? Answer questions, earn points and help others
