Tv still have power LED light indication,tv still have power wright?Yes.Tries tv unplug,replug it back like an hour later.For the tv resetting itself back to factory setting.See if ur tv take in and reboot up with the new upgraded firmware.
Now, with new firmware successfully installed, though the tv worked very briefly, it is now completely dead. Even the power L e d light does not come on.
Now,than nothing to do with the software firmware updated.Ur tv power supply board is dead.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
1. From the printer control panel, touch Ink Levels
> More Options > Replace Printhead.
2. Open the printer cover. Note: If the carrier does not
automatically move to the center, turn off the printer/unplug the printer from
the power source and then slide the carrier to the center.
3. Press the tab, and
lift the latch. Pull up to remove the printhead. Close the printer cover then
turn off the printer/unplug the printer from the
power source.
4. Turn the printer back on. It will ask you to
"Open Cover to Install the Printhead". Press the Home icon. It should take you back to
the "Copy" menu.
5. Proceed with the firmware update. Just go to http://bit.ly/p905fw.
6. Once the firmware update is successful, firmly re-insert
the printhead.
If problem continues, please contact Lexmark technical support for additional assistance.
