Black & Decker Pivot Plus Cordless Drill/Screwdriver Logo
Posted on Feb 25, 2011
How do i put a small drill in the pivot i think i
How do i put a small drill in the pivot i think i may be missing the neccessary adjustment
Kjell Bjornar Amundsen
Level 1:
Habit-Forming:
  • Contributor 57 Answers
  • Posted on Feb 27, 2011
Contributor
Level 1:
Habit-Forming:
Answers
57
Questions
0
Helped
33024
Points
93
Hi
These drills have hexagonal tool holders, and does not have an adjustable chuck like larger drills do. However, I recommend drill bits with hexagonal bases whicha are readily available at any tool store these days.
Good luck
Replacingvbelt
the belt. are both those on same belt.?
there are only 3 types of adjustments on all cars.
1: manual adjuster.(on P/S or ALT, just use is pivot) look.
2: spring adjuster. (if missing, its not this)
3: manual dedicated pivot adjuster. (if missing, its not this)
it varies by engine type.
this car had these ,what is yours?
1.3 L I4; 1.5 L I4; 1.6 L I4; 1.8 L I4; 2.0 L I4; 2.3 L I4; 1.4 L Diesel I4
tip
Clock Bushing Replacement
BUSHING TIPS
-One of the most common stoppage problem is caused by increased friction and mostly due to lack of incorrect amount of or lack of oil. If discovered in time, the movement can be cleaned and oiled with only high quality Clock oil, then it will be good for another 5 years or so. Insufficient lubricants eventually cause wear in the pivot holes and/or bushings.
-After a pivot is worn it will change the depth of the wheels and pinions to such an extent that the power train will stop due to improper gear meshing. Wear causes a pivot hole to become egg shaped.
HOW TO TEST
-One testis to completely let off the power from the power train and rock the main wheel back and forth. Then you will clearly see the pivots that have the problem jumping back and forth.
Sample one:
Sample two:
Examples of EGG Shaped pivots above.
WHEN DO YOU NEED BUSHING REPLACEMENT?
-One rule of thumb used by many repair persons, if a bushing is worn one third or more the diameter of the pivot it needs to be replaced.
-Above is Two example of a worn pivot's [note the black gum med up oil around the pivot in photo above]. This is a dead give away of a potential problem.
centerline PIVOT
-Before disassembly, mark all bushings that need replacement in the correct geometrical direction of centerline.
-Complete disassembly of movement is required.
-Then you will need to file out the exact opposite direction with a small file, this will ensure that when you start drilling out the hole it will be centerline.
-Set-up the drill press and lock the plate on to the drill press making sure you find the centerline of the original pivot hole. Use a steel short stock the same diameter of the old pivot and chuck it in the drill press after the plate is secure, select the proper bushing that you intend to press in.
PRESSING IN THE BUSHING
-With a small broach taper slightly the inter plate before the insertion of the bushing. Do this from the inside of the plate, this will ensure that the bushing will never fall out.
-Select a bushing that is a bit undersized after it is pressed into place, then open the hole up to the correct diameter.
-Use the drill press to push in the new bushing from the inside plate out.
-Be sure to broach out the pivot bushing in both directions, this will leave the hole in an hour glass shape ”===)I(===” and will reduce friction.
COUNTER SINKING.
- Counter Sinking is very important and not only needed to hold the oil in place but also to reduce the amount of actual friction on the pivot. [Note:] don't get carried away the first gears tend to have a lot of torque on them and a lot of bushing surface is needed; however, the final pivots do not and are very sensitive to friction.
-Barrel Bushings, these are often overlooked. This is an example of a bushing before and after replacement.
Hope this tip helps.
R/
David
http://antiqueclock.clockstop.com/bushing.htm
on Jan 22, 2010 • Watches
Changing the chuck of a 6408 makita electric drill
Open the chuck and remove the screw inside the chuck (if fitted) the screw is left hand thread, fit the short end of the largest hex key that will fit into the chuck and tighten the chuck, put the drill into low gear and turn the clutch to the drill position, support the drill on a bench and strike the long end of the hex key with a firm blow (right hand thread) it may be neccessary to strike it more than once
Pivot Plus. Cannot remove screwdriver bit
use soe WD40 and a pair of pliers, i take it that it has been left in it for a while. put it in the lock position when you are trying to get it out. if you do not have wd 40 then use some light oil, it is probably rusted in position.
cheers
iain
1helpful
HOW DO YOU ATTACH A DRILL BIT TO THIS TOOL? i can
it is not a drill, it is a driver. Unless you change the chuck or add one onto it,. sorry to say., it ain't happennin...
Best regards
Ck
I have a pink black & decker cordless drill which I use for small household tasks. However, my husband uses this too for small jobs. My problem is the ac adapter has gotten misplaced & I need one....
Contact Black and Decker (Dewalt) at 800-235-2000-you should be able to get number for an authorized repair center that can supply it for you-but it may be cheaper to replace the whole thing.
We used, what we think is the correct charger,
Dave,
 see this black and descker website
http://www.blackanddecker.com/productguide/product-details.aspx?productid=6150&toolview=5#
The product number is PD600 and you can look up new chargers there.
Dewalt do the part, which is 871     5102767-03
1     CHARGER    Cost    $4.06
Bit problem
Just read part of the manual and it says hold tool upright and pull down on the collar and "simply" remove the accessory. If this is not the case on yours I would have to think that the shank on the bit may be twisted and then you would have to find another method to remove it. Let me know if the second opinion is correct. Good luck
this one dosn't charge. It takes batterys. how do i change them
10helpful
2answers
Black & Decker Pivot Plus Cordless Drill/Screwdriver AC Adaptor
extend the handle straight and all will be reavealed! Just in front of the triger inside the piviot point.
Mike
Top Black & Decker Drills Experts
Sean Wright
Sean Wright
ADMIN Andrew
ADMIN Andrew
Paul Carew
Are you a Black & Decker Drill Expert? Answer questions, earn points and help others
