Ovens Logo
Posted on Feb 25, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Stove does not heat up past 250 in over 1 hour, checked the coil and it is not broken, whole oven heats when clean cycle is turned on, but not when just heating by temp only
mark warfield
Level 3:
  • Master 453 Answers
  • Posted on Feb 25, 2011
mark warfield
Master
Level 3:
Answers
453
Questions
Helped
150914
Points
1130
YOU MIGHT HAVE A TEMPUTURE LIMITER ...IT WOULD BE UNDER TOP HOUSING COVER IF ITS THERE...TIE CLIPPED TO THE WIRES...IT LOOKS LIKE A BULLET...IF NOT CHANGE THE STAT ASSY OR CHECK YOUR CONTROL SWITCH SEE IF ITS MELTING ON CONTACTS ALSO LOOK AT YOUR MAINS CABLE BLOCK ...BOTTOM RIGHT HAND SIDE REAR. UNDO COVER SEE IF MELTING COMMON FAULT. .....BSC APPLIANCES 07779933829 UK
Anonymous
Level 3:
  • Master 1,531 Answers
Anonymous
Master
Level 3:
Answers
1531
Questions
0
Helped
406855
Points
4453
You may need to change the oven temp probe.or the main electronic control board
Model mer5875qas oven wont heat after self clean cycle
IF there is no error code on the display, you need to unplug the stove and check the heating coils with an ohm meter to see if they burned out. If they are ok, then you need to order the temp sensor, if they are burned out, replace them http://www.appliancepartspros.com/parts-for-maytag-mer5875qas.html
Dec 03, 2017 • Ovens
1helpful
Oven temperature will not cycle
How To Fix Oven With Little or No Heat When Baking ...
www.partselect.com/Repair/Range-Stove-Oven/No-Heat-When-Baking/
Repairing a range, oven, or stove can seem like a big task, but our ... Most electric ovens use both the bake element and the broil element in a bake cycle, with the bake... If the bake element isn't working, the oven may not reach the set temperature or ...If the element appears to look normal, then turn the oven on to a bake ...
Electric Stove Repair ' Electric Oven Repair Manual ...
www.appliancerepair.net/oven-repair-4.html
Inside the oven, the heating element is called a "bake" or "broil" element. ... To maintain a set temperature in an electric cooktop, the element is cycled on ... Do not put any cleaning agents or solvents directly on heater elements or surface units. ... A switch will show no continuity when off and good continuity when turned on.
Electric Oven Will Not Heat ' RemoveandReplace.com
removeandreplace.com/2015/.../oven-not-heating-how-to-fix-range-repa...
Aug 24, 2015 - The issue is most likely a bad internal fuse, oven temp sensor, ... oven replacement parts ... Bake and Broil Element Test - Electric Oven Repair ... Dryer Spins But No Heat - How To Troubleshoot Dryer is turning the drum but ... If your dishwasher is completing the wash cycle but will not dry your dishes, we ...
Oven Temperature Not Accurate - Repair Parts ...
My frigidaire gallery series oven made a popping noise while heating up dinner in oven and now the whole oven is not working
Hello jnjpelli - Try resetting the unit by unplugging it or flipping the household circuit breaker off. Wait approximately ten minutes and restart the unit. If the oven does not turned on, then more than likely there seems to be a power supply issue. Also try checking the breaker and the power connections located on the back of the range. If any of these suggestions prove to be ineffective, connect with a professional to accurately pinpoint any potentially more serious issues
2helpful
Hotpoint oven won't heat above 250 degrees broiler works fine as well as the stove top
either its the oven sensor rod located at the top of the ovens cavity,or your bake element could be getting a hot spot which is when it gets a discolored spot in the element and can no longer pass sufficient current to heat the oven past 250 degrees
Oven wont heat
That depends if the oven is electric or gas.
If it is electric, it can be heating element, temp probe, or control knob/buttons, board and wiring.
If it is gas it can be the igniter (check spark) , the thermostat, the safety valve that prevents accidental gas flow, or the control.
If the oven has self cleaning cycle, check that it is not stuck on self cleaning, try unplugging for a while and restarting self cleaning cycle in that case.
Check also What is wrong with your Range/Stove/Oven?
Mar 29, 2009 • Ovens
2helpful
Jenn-Air stove locked
After the lock indicator light goes out, move the door lock lever to the left. The oven door can now be opened. Turn the selector and temperature knobs from clean to off AFTER THE DOOR IS UNLOCKED. If the temperature knob is turned to off BEFORE the door is unlocked, the door will not open. Forcing the lock will damage the lock mechanism. If this should happen, return the temperature knob back to CLEAN, unlock the door, THEN turn the temperature knob off. Source(s): Jenn-Air Grill Range with Self Cleaning Radiant Bake and Convection Oven models S136, S156, S161
Dec 10, 2008 • Ovens
Top Maytag Ovens Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Paul Carew
Are you a Maytag Oven Expert? Answer questions, earn points and help others
