Question about Ovens
How do i turn on a white atlas ceramic electronic oven, the ceramic top is working,but the oven screen flashes from"0:00" to "auto" when i try and fiddle round with the oven dials.. it just wont work
    Champion:
  • 235 Answers
Turn the oven control on. Now play with the buttons on the electronic timer/clock. Try all different combinations. Trying pressing them at the same time. This may take 5 minutes or more. If the timer is not faulty this will work, be patient. When the oven indicator light comes on the oven is on and the timer is now in manual mode.
Posted on Feb 26, 2011
Testimonial: "thank you,ill try it"
6ya staff
SOURCE:
What is the worst that could happen if an electric double oven ceramic hob had the neutral and earth mains power wired the wrong way round ?
Electronic controller would most likely be damaged and need to be replaced. These things usually cost between $350-$400
Nov 28, 2014 | Ovens Ovens
Es510
Hello KC - You may try and reset the cook top by disconnecting the power to the unit for up to 30 seconds by flipping the circuit breaker off and back on. This often clears most false error codes. If the lock symbol does not clear, then the unit more than likely may be experiencing an issue with the EOC (Electronic Oven Control), user interface board or a potential wiring failure. This is not a typicaly do it yourself job; please consult a professional or your manufacturer.
Apr 28, 2013 | Frigidaire 30" Self-Cleaning Freestanding...
I just moved in to a house with a GE eletric range/oven with a ceramic range top. When I press the bake button the screen flashes a message to unlock the door. But the door is unlocked. I tried lockin
Alway unplug or turn off the breaker to any appliance your are attempting to repair
Sep 30, 2012 | Ovens
Electric range flashing "F1"
EOC is the Electronic Oven Control. if you have major sparks I would call a service tech because there is an underlying cause that needs a trained eye to be sure it is safe for you to use.
Jan 30, 2012 | Frigidaire Ovens
Hi there Have recently moved into a house with a Belling 626 white, electric cooker and the grill doesn't seem to be working. It has a mian oven, top ovem and "dual grill". The main oven...
ISOLATE THE MAINS POWER BEFORE CHECKING THE APPLIANCE
Run your fingers along the grill element, in this model it is accessible, check for raised areas or small hole or roughness not food burnt, if visible, it should be Black Grey colour at the blemish, you can obtain parts from www.whitegoods.co.uk you will need the model and serial numbers.
The grill elements come out but when unsrewed sometimes the ceramic holders crack, remove element before ordering as you may have to replace the element holders.
Hope this has been helpful
john
May 31, 2011 | Belling Ovens
Oven will not heat. all the burners on top work fine. what could be wrong?
Usual faults in this order are:
Faulty oven element - check element for holes, blow marks etc;
Burnt off wiring at the oven element terminals - check terminals;
If the oven indicator lights when the oven is turned on it should be the above. If it does not refer below;
Electronic clock set to auto. mode instead of manual mode.
Feb 12, 2011 | Frigidaire 30" Self-Cleaning Freestanding...
My right front burner will not turn off on my electric stove top.
Its probably the switch for that element, the contacts are fused. If this is a smooth top ceramic stove then the control relay board relay for that element is stuck.
Dec 20, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
Replacing the ceramic top
I remove the whole hinge and top from the back put the old hinge on the new top then move the burner to the new top put the whole hinge on the back of the oven.. hope is is a little help
Jun 11, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
F3 Fault
Either your new temp probe failed or there is a wiring problem between the probe and the electronic relay control.
Jul 29, 2007 | GE JKP28 Electric Double Oven
Ovens Logo
381 people viewed this question
Top Ovens Experts
Marvin
Marvin
Are you an Oven Expert? Answer questions, earn points and help others
