Hi, your ipod displaying data and not playing might be because you did not transfer the music properly or the format of the music does not play on an ipod.
You will need a converter to help you convert songs into an ipod format. Download from the below link:
effectmatrix.com/total-video-converter/
You can follow the instruction below to know how to transfer music into an ipod.::
Most common problem for new ipod user is how to put music onto ipod. So I created this ipod tips to solve this problem. Windows media player is not able to upload songs to ipod. You must use Apple iTunes to get music onto your iPod. Windows Media Player can see the iPod as a hard disk. But not able to copy upload music from pc to ipod.
The steps to put music onto an Apple iPod with itune.
When you plug ipod to your pc first time through USB, you might get this pop up message. If you have already installed itune .
You need to restart your computer to install ipod and then the next time you start up, your iPod will not generate any messages of this nature.
You need to install itune on your computer if you have not installed itune. You can simply go to apple.com/itunes to download the latest version. It also comes with ipod CD.
The next step is to launch the iTunes program. And it will recognize the ipod that you have plugged in
It shows one message to give name to ipod, You can stick with the default name for your device or give name to ipod.
I also uncheck "automatically update music" because I like to control what happens to my iPod manually.
When you're done with this configuration step, click "Next" :
register your iPod, or just click "Finish".
Step 1
Now, finally, you can see iTunes and also your ipod inside your itune:
Click on whatever name you've given to your own iPod, and you'll see your music list, which is completely blank:
Now click on the "Library" link on the left column and you'll see what albums or music you've copied into your iTunes library. Or click on the "Browse" button on the top right (it looks like an all-seeing eye) and a new panel will show up with lists of songs, artists and albums.
Now select the song you want to put on to your ipod. then dragging and dropping that onto the name of the iPod on the left side panel of your itune. Now your song are copied to ipod.
Hope it helped.
Feel free to pass your comment.
Good luck..
SOURCE: I can not play
Use itunes. It's made to work perfectly for the ipods. You can update the firmware and software using that. You can do a lot with itunes.
Change tags, info, and make playlists, update the whole ipod, reformat it so it's like new.
