Kenmore Elite 45986 Front Load Washer Logo
Posted on Feb 25, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My Kenmore Elite HE5T front loading washer is giving me an F20 (Water inlet problem - no water or insufficient water supply) code. The Drum fills half way up with water in about 5 minutes and then the code comes on. There doesn't seem to be an insufficent amount of water. I checked the drain and it is clean and clear. Any other suggestions?
Anonymous
Level 3:
  • Master 1,940 Answers
  • Posted on Feb 25, 2011
Anonymous
Master
Level 3:
Answers
1940
Questions
0
Helped
954263
Points
5951
The F20 error deals with the water coming into the tub. The F20 code indicates the control didn't see any water enter the tub.
  1. There is a flow meter that tells the control water is coming into the washer. If the flow meter is faulty the error usually happens quickly.
  2. Near the pressure switch is a clear plastic hose may be kinked or even have a small hole in it. Check the drain line first and then remove the top of the washer to access the pressure switch and pressure hose. With the washer empty remove the hose from the pressure switch located on the right side of the washer and blow through it to clear any debris blocking the pressure hose or air trap.
  3. If this doesn't help then most likely you will need to replace the pressure switch.
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
I have HE5t kenmore front load washer that displays a "f20" code. the washer starts to fill and then stops filling and displays the code
f20 code you have problem with inlet valve check screen in the valve maker sure they not clog with dirt
3helpful
F20 error code
Hi.
F20 means that there is a water inlet problem:
Reasons for error F20:
(Water Inlet Problem-no water or insufficient
water supply) Select PAUSE/CANCEL twice to cancel the cycle
Unplug washer or disconnect power.
Check the following:
Are water faucets completely turned on?
Are screens at inlet hose connection to washer
clogged? Are water inlet hoses kinked? Are water inlet hoses frozen?
If that does not help inlet valve, pressure switch and control module must be tested. The defective part must be replaced.
Here the tech sheet.
Regards.
Ginko
Code problem on the machine is F20
"F20" on display
water supply)
Unplug washer or disconnect power. Check the following: Are water faucets completely turned on?
clogged? Are water inlet hoses kinked?Are water inlet hoses frozen?
also, those flood prevention hoses they sell you don't work well with front load washers
I have a error code washer mayta f20
"F20" indicates a water inlet problem (no water or insufficient water supply) in your washer. To resolve this issue check your washer inlets, maybe the water valves are off or you don't have enough water pressure.
Thank you!!
I have a kenmore elite HE5t steam front load washer that keeps putting up f20 error the water lines are not plugged water is flowing into it i moved it out to check the water lines and it ran 3 loads then...
http://www.fixya.com/support/r3608632-f20_error_code
This code is tricky to troubleshoot, so jsrock516 advices to eliminate the easy common sense items first.
3helpful
Error Code F-20
I have same machine and manual says, "F20" on display (water inlet problem - no water or insufficient water supply). Select STOP twice to cancel the cycle. Unplug washer or disconnect power. Check the following. Are water faucets completely turned on? Are screens at inlet hose connection to washer clogged? Are water inlet hoses kinked? Are water inlet hoses frozen? Plug in washer or reconnect power. Re select cycle and press START. if the problem remains, call for service.
2helpful
Have kenmore elite HE5t giving code F20 help pls
The following link explains the "F20" error code:
http://www.fixya.com/support/r1491905-f20_error_code_whirlpool_duet_kenmore
I recommend checking your washer installation for a possible siphoning condition and kinked fill hoses, first, as these are the easiest items to rule out.
If you have questions, please let me know. I hope this helps you.
Kenmore Elite quiet pak 4
its a inlet water supply error code check your cold fill line and fill screens at cold fill valve for block
Alexander
vince
