I was given an i pod shuffle as a gift from a friend but when i went to apple support the i pod had been disabled. how do i fix it so that i can put my own apple itunes on. thanks anne marie
Re: I was given an i pod shuffle as a gift from a friend...
To reset iPod shuffle:
Disconnect iPod shuffle from the computer (if connected).
Move the switch on the iPod shuffle to the OFF position. Note that when iPod shuffle is off, the green stripe by the switch is not visible.
1st generation
2nd generation
3rd generation
4th generation
Wait five seconds. For iPod shuffle (3rd and 4th generation), wait ten seconds.
Move the switch to the play in order or the shuffle position. The green stripe will be visible in either position. For iPod shuffle (2nd and 4th generation), slide the power switch on (and you can see the green stripe).
thank you that would be fine if i had the code apple tunes does not recognise the devisethank you that would be fine if i had the code apple tunes does not recognise the devise
By resetting the device the code will be erased from the ipod and you will be able to set the iPod up as if it is brand new.By resetting the device the code will be erased from the ipod and you will be able to set the iPod up as if it is brand new.
You can't post conmments that contain an email address.
Not sure what happened with your device. If the problem keeps occur, you can try a 3rd party iPod music transfer program on your computer. How to Transfer Music to iPod without iTunes
If it's an iPod Shuffle, just go to http://apple.com and download the latest version of the iTunes software. iTunes takes some time getting accustomed to but you'll figure it out :)
The iPod Shuffle does not come with a charger. It charges through the small connector that connects the iPod to your computer via the USB port.
Your I-pod is in "shuffle mode". To remove it out of shuffle mode, turn the shuffle mode switch to "off" This switch is located on the bottom right side of unit.
Are you running the most current version of iTunes? If not try upgrading. After that, try seeing if there is an firmware upgrade. If there is, try upgrading that too. Then try reuploading songs. If it is still not working, it might be damaged or just not working anymore. Only use Itunes when uploading songs to ipod regardless of type.
HI WE REPAIR ALL OUT OF WARRANTY PDAs,BLACKBERRY ,APPLE IPODS,IPHONES, AND APPLE LAPTOPS SERVING EAST DELHI,WEST DELHI,NORTH DELHI,SOUTH DELHI,NCR,FARIDABAD,GURGAON,NOIDA PLEASE CONTACT US AT JULIAN JOHN : Preet Vihar, Vivek Vihar, Shahdara, Mayur Vihar, Patparganj and Lakshmi Nagar. Pitampura - Rohini - Punjabi Bagh. - JanakPuri - Rajouri Garden - Patel Nagar
Please restate your issue.If i understand it correctly you would like to recover your iPod shuffle is that correct... That wont be possible you can not recover an iPod shuffle do to it's settings.
Thank You,
Apple Care Service And Support
Nick M.
Reference#:7834AC
hi ya,
Well firstly to use any Apple iPod products you need iTunes, which you can download form [http://www.apple.com/itunes/download/] for free if you don't already have it installed
once you have this installed, check this article form apple its great, will get you on the why to be a iPod guru ;)
http://www.apple.com/support/itunes/windows/tutorial/index.html
