Computers & Internet Logo
Posted on Feb 24, 2011
It always said to me error 401 - Computers & Internet
Anonymous
Level 1:
New Friend:
Welcome Back:
Visited the website for 2 consecutive days.
  • Contributor 2 Answers
  • Posted on Feb 24, 2011
Anonymous
Contributor
Level 1:
New Friend:
Welcome Back:
Answers
Questions
0
Helped
847
Points
6
Error 401 means that you can't access a web site. To fully understand the error and how we need to try and help you fix this we need to know what HTTP Error 401 - you are getting.
Example: HTTP Error 401 - Unauthorized: Access is denied due to invalid credentials.
  • tracy stella Sep 29, 2011
    That is my error message. I can't access my hotmail account that I've had for more than 10 years. My life is in there. I've already received the numeric code to "unlock", and it didn't help. Just keeps bringing me to the "401 - Unauthorized: Access is denied due to invalid credentials" error message. Please help!
RICOH Aficio MP W2401 FUNCTIONAL PROBLEM SC 401
Ricoh Aficio 240W Plotter Error Code SC 401-00
Copytechnet https://www.copytechnet.com > forums > 108927-rico...
May 4, 2016 - On old Ricoh Aficio's SC401 used to be a Transfer error, but on the 240 its ID Sensor, could be dirty, could be old Dev, could be a loose ...
Ricoh MP2352 SC401- Strange problem
Jul 28, 2021
Error Code SC-401
Sep 12, 2014
ricoh mp 3352 - error sc401
Dec 11, 2020
Ricoh mp 2851 SC 401
Jul 11, 2017
More results from www.copytechnet.com
Error Codes > Ricoh > MP2553 > Code SC401
Printcopy.info https://printcopy.info > code=SC401
Code: SC401 · Description: Transfer positive electrode current error A transfer roller current leak signal is detected. · Causes: • High voltage supply board set ...
Missing: W2401 ‎' Show results with: W2401
Error Codes > Ricoh > Aficio 2090 > Code SC401
Code: SC401 · Description: Transfer roller open error · Causes: • Transfer power pack defective • Poor connection between the transfer current terminal and the ...
" 401 unauthorised " is the error message i
No, but you can just reset the whole router and start from scratch. Hold the reset button on the rear of the router for 60 seconds and your will restore the unit to defaults, at which point you just need to reconfigure all of your configuration settings and password, as well as your wireless access code. Let me know if you require any additional assistance.
1helpful
2answers
Error message - system error T02-405 how can i fix this
T02-401 and T02-405 is the elevator motor (paper tray up movement) is binding in some way.
1helpful
What should I do when 401 unauthorized is happened?does it have any relationship with my modem? best Regards
401 error: Generally this error message means you need to log on (enter a valid user ID and password) somewhere first. If you have just entered these and then immediately see a 401 error, it means that one or both of your user ID and password were invalid for whatever reason (entered incorrectly, user ID suspended etc.).
Are you trying to access your modem's gui?
additional info/reading:
http://www.checkupdown.com/status/E401.html
2helpful
2answers
Keep getting a 401 unauthorized code when trying to log in to sur
Your Web server thinks that the HTTP data stream sent by the client (e.g. your Web browser or our CheckUpDown robot) was correct, but access to the URL resource requires user authentication which 1) has not yet been provided or 2) which has been provided but failed authorization tests. This is commonly known as "HTTP Basic Authentication". The actual authentication request expected from the client is defined in the HTTP protocol as the WWW-Authenticate header field.
401 errors in the HTTP cycle
Any client (e.g. your Web browser or our CheckUpDown robot) goes through the following cycle:
Obtain an IP address from the IP name of your site (your site URL without the leading 'http://'). This lookup (conversion of IP name to IP address) is provided by domain name servers (DNSs).
Open an IP socket connection to that IP address.
Write an HTTP data stream through that socket.
Receive an HTTP data stream back from your Web server in response. This data stream contains status codes whose values are determined by the HTTP protocol. Parse this data stream for status codes and other useful information.
This error occurs in the final step above when the client receives an HTTP status code it recognises as '401'.
Fixing 401 errors - general
Each Web Server manages user authentication in its own way. A security officer (e.g. a Web Master) at the site typically decides which users are allowed to access the URL. This person then uses Web server software to set up those users and their passwords. So if you need to access the URL (or you forgot your user ID or password), only the security officer at that site can help you. Refer any security issues direct to them.
If you think that the URL Web page *should* be accessible to all and sundry on the Internet, then a 401 message indicates a deeper problem. The first thing you can do is check your URL via a Web browser. This browser should be running on a computer to which you have never previously identified yourself in any way, and you should avoid authentication (passwords etc.) that you have used previously. Ideally all this should be done over a completely different Internet connection to any you have used before (e.g. a different ISP dial-up connection). In short, you are trying to get the same behaviour a total stranger would get if they surfed the Internet to your Web page.
If this type of browser check indicates no authority problems, then it is possible that your Web server (or surrounding systems) have been configured to disallow certain patterns of HTTP traffic. In other words, HTTP communication from a well-known Web browser is allowed, but automated communication from other systems is rejected with an 401 error code. This is unusual, but may indicate a very defensive security policy around your Web server.
Fixing 401 errors - CheckUpDown
When you set up your CheckUpDown account, you may optionally provide two items 2. Web Site User ID and 3. Web Site Password. You should provide these only if your site uses HTTP Basic Authentication. If you provide them, the CheckUpDown robot always uses them. This will result in a 401 error if in fact your site does not use this authentication. Conversely, if you do not provide them and your site does use this authentication, you also get a 401 error.
If however your URL is open to all comers, then an 401 message should not appear. Because it indicates a fundamental authority problem, we can only resolve this by negotiation with the personnel responsible for security on and around your Web site. These discussions unfortunately may take some time, but can often be amicably resolved.
Alternatively or the other way around is :
open the XP hosts file, and do a manual insert there.
The hosts file is located at: C:\WINDOWS\system32\drivers\etc
The entry is: 192.168.0.1 www.routerlogin.net
You might need to flush your DNS records at this point, or simply restart your computer.
And then use the following URL to access the admin page:
http://www.routerlogin.net/setup.cgi?next_file=start.htm
***Here is another solution to the problem, which is a fairly straight-forward way to disable the annoying wizard.
Type in your browser:
http://www.routerlogin.com/CA_HiddenPage.htm
Select: Disable Configuration Assistant, and click on Apply.
You can re-enable it by navigating to http://192.168.0.1/CA_HiddenPage.htm (where 192.168.0.1 is your router’s IP address)
1helpful
When faxing a 401 error is reported
error 401 means that your number is not programed in the machine you are trying to , so it blocks it
5helpful
4answers
Ricoh copier aficio 401 error sc 419
hi im jules_09.
sc 401 means transfer roller leak error.a transfer current leaksignal is detected.posible causes is 1.transfer power pack is defective 2.poor connection between the transfer terminal and the trnsfer power pack
sc 419 mean quenching lamperor.1 quenching lamp defective 2.poor conection between power pack and quenching lamp.
check all component but pay attetion to the current leak at the transfer because there both connected at the power pack
Grand Canyon Tech
Grand Canyon Tech
