Thanks for visiting FixYa!
Although you refer to the model number of your phone as a Dect 6.0 43-260 I've only been able to locate the instructions for a Dect 6.0 43-259. Hopefully, they are close enough.
This is a link to the Quick Start guide:
http://www.radioshack.com/graphics/uc/rsk/Support/ProductManuals/4300259_QS_EN.pdf
This is the link to the User Guide:
http://www.radioshack.com/graphics/uc/rsk/Support/ProductManuals/4300259_PM_EN.pdf
The User Guide explains how to record your own personal greeting as follows:
(See Page 50, Recording a Personal Greeting)
Your answering system comes with a pre-recorded outgoing message or
greeting that plays when you receive a call: "Hello, no one is available to take
your call. Please leave a message after the tone." You can record your own
personal outgoing greeting. Your recorded greeting must be between two
seconds and thirty seconds long.
1. On the base, press MENU/SELECT.
2. Select the ANS. SETUP menu, and then the RECORD GREETING sub-menu.
3. RECORD GREETING, START [SELECT] appears. Press MENU/SELECT
to start the recording. Begin recording after the announcement.
The message counter on the base LCD displays "30", and then begins
to count down.
4. When you finish recording, press MENU/SELECT again or press (key and LED (play/stop) . You
will hear a confirmation tone, and your recorded greeting plays back for you.
I hope this helps.
Hi Ken.
Here the manual for Presidian 43 series.
Regards.
Ginko.
Thanks for the manual but it was not the correct one. Specifically the contents did not list how to create and change and answering machine message. That is really what I need to know
If you can give me further help I would be very grateful.
Ken Kobza
