I think this indicates thet ypou have a fixing film rotational error. When the fixing motor is driving, the marker signal has not been detected for 6 seconds or more.
Check the fixing unit, and repair as needed.
Reset this in service mode Enter service mode by pressing *, 2&8 keys together, then * again. Go COPIER>FUNCTION>CLEAR ERR
E002/E000/E003/E261/E733 Error code: Due to AC line noise Error Code
Symptom
E002/E000/E003/E261/E733: due to AC line noise.
Description
E002/E000/E003/E261/E733 occur due to AC line noise. If the above error codes are frequently recorded in the error log, they might concern AC line noise.
Cause
When the machine tries to detect a Zero-cross signal of AC line, it will fail if a noise occurred around the zero-cross point. Since the fixing temperature is controlled based on the zero-cross signal, there is a possibility that the fixing temperature could not rise properly if a noise occurs several times.
Field Remedy
Replace the Switching Regulator PCB ***'y with a new one. 120V: FH3-2613 220V/240V: FH3-2614 The circuit has been modified to resist a noise.
REMEDY
Caution Press (* then 2 and 8 together then *)you are in service mode monitor:To clear the error, execute the following in service mode: COPIER>FUNCTION>CLEAR>ERR.
