I have a doro cordless phone with an additional handset the model no is doro arc 3+1 & I have lost instructions when I make a phone call the numbers click for ages and if I have to press nos 1 or 2 etc once through this does not work can you help?
thanks for instructions I have set it all up correctly do you think I should reset my base setting will I lose all my numbers I have input?thanks for instructions I have set it all up correctly do you think I should reset my base setting will I lose all my numbers I have input?
thanks for manual I have set it up correctly do you think I should reset basethanks for manual I have set it up correctly do you think I should reset base
You can't post conmments that contain an email address.
If you are in troubles because the phone is malfunctioning, then reset base, and re-enter contacts. If the phone is working OK, there is no need to reset the base Hi.
This is because the extra handset might have not been registered with the base unit.The headset should be register to use the headset with that base unit.
To register the handset to base unit please follow the instruction:-
On registration the handset is allocated a handset number for use on the new base unit, the handset numbers are 1-5.
1. Press and hold on the base unit until starts flashing. Registration mode will remain active for approximately 3 minutes. 2.Press and hold both together until you hear a long beep.
3.Select the base unit you wish to register by pressing the corresponding number button 1-4. 4. When PIN is displayed, enter the units PIN number (0000 for this model). 5. If the registration is successful the handset will return to standby mode in a few seconds. Thanx
goto this wepage put in your model number and you can download your replacement manual. http://www.doro.com/global/businessunit/dorohome/support/manuals
Reset base unit defaults Resetting will return most functions to the original factory default setting. Registrations are not affected by resetting. 1. Press Menu. 2. Scroll using v/V to Base Set. Press OK. 3. Scroll using v/V to Default Set. Press OK. 4. Enter your current base unit PIN code (0000 at default). 5. Press OK to confirm.
Have you tried it with other batteries? The handset will be dead on
the cradle regardless of juice from the wall, if the batteries are
missing or no good. This unit eats batter juice quickly if left off
the cradle for any length of time.
Problem fixed.......after a call this morning to Doro tech support. It was a simple fix..........simply hold down the # key to lock or unlock the keypad. Unfortunately I had overlooked that section in the manual.
I have replace my doro batteries with Duracell rechargeables, just make sure you fully charge them before you put them in the handset. If you find after a time that the charge goes again, charge them again (in the charger you buy when you buy the batteries)! Hope this helps. PS, do you know how to turn the answering machine on?
