SOURCE: My n70 only shows white screen!!
my cell phone did the same thing, there is no solution-most likly caused by humitity, just send it in for a new cell phone.
SOURCE: Nokia 6120c will not turn on after strying software upgrade
ur phone is affected by wsod (white screen of death) problem caused by waterlogging in the phone or phone memory full . very sorry about thaat.
SOURCE: Hi, when i turn my
Yes, Nokia has its white screen problem. I think what you can do is just once check with your NOKIA dealer for this problem, it could be because of the problem with the display IC chip, it might have gone bad.
SOURCE: my nokia 5220 express music's screen turns white
try to put out the simcard...then open it...or your mmc is almost full so delete some files...i hope this helps
SOURCE: nokia 5130: blank screen, phone doesn't turn on
That means your phone got a corrupted software installed to its memory. A hard phone reset can solve this problem. Typically a nokia symbian series phone can be formatted using this code *#7370# then the default key is 12345.
Hope this could help.
Testimonial: "yes, it did get corrupted by a software and I had to give it to some workers at nokia to fix it, I lost the info on the phone (except memory card)"
