Question about Bunn A10 Coffee Maker
COFFEE MACHINE KEEPS FIL;LING UP AND OVERFLOWS. tHIS IS A BUNNOMATIC MODEL STPF-15
    New Friend:
Dunkin Donuts decaf coffee clogs the filter as the water fills the basket causing the basket to overflow. The coffee is ground too fine. Swtich brands or use a second filter to cover the coffee grounds to keep them from floating and clogging the filter.
Posted on Feb 25, 2011
6ya staff
SOURCE:
Machine overflows around kcup and keeps pumping water until resevoir is empty, help don't want to throw away
Do you know what brand/make your coffee machine is, without that information you will only get guesses, most probably useless.
Sep 30, 2017 | Coffee Makers & Espresso Machines
When I push the "espresso" button of my nespresson essenza automatic, it just keeps running until the espresso cup overflows. It has never done that before.
Did you shut your machine off? you just have to reset it. That has happened when I descaled machine. You need to hold the button for as long as you want the cup to fill. ex. hold the button down and count 15 secs. Next time you use the machine it should fill for the 15 secs. (use a used pod so you don't waste the good coffee). That has always worked for me. I had to set both sides (small cup and large cup, you my have to also). hope this helps!
May 07, 2010 | Nespresso Essenza C100 Espresso...
Water not filtering quick enough, basket overflows
Make sure your sprayhead is the proper one (5 hole) and in good shape. Also make sure that the hole on your filter basket has not been partially closed. This can happen if you set it on the hot warmer. As a last resort, you can slightly enlarge the hole in your filter basket.
Apr 28, 2010 | Bunn BX HOME BREWER 10-Cup Coffee Maker
Pour in one full caraffe of cold water when the machine is not switched and cold.the water immediately runs out. The switch on and it keeps on boiling. Should it not switch of when temp. is reached. Model...
www.bunnomatic.com/pdfs/commercial/manuals/33545.0000. From what I understand the swithc is to stay on at all times unless you are going to be away for awhile. The water you are pouring in will be the reseve for the next pot. I'm not sure if it should be boiling but check the filling instructions from above . I had no idea how to fill as mine was bought used. Good Luck! God bless!
Feb 14, 2010 | Bunn Pour-O-Matic VPR
Coffee doesn't fall in bag (bunnomatic G1 coffee grinder)
keep clicking the De-chaf lever on the right. This tamps down all the loose grounds. Static is common with coffee due to the low humidity of the grounds (even here in Hawaii) try attaching a small metal chain to the grinder case with a used coffee clip on the end of the chain to attach to the empty bag. This will help it 'ground' out the static to the case.
Feb 10, 2010 | Bunn -o-matic G1 (1 lb. Bulk Grinder)
Should I leave the Bunn Pour Omatic Coffeemaker plugged in at all times?
Yes, the coffee maker keeps a tank of water pre-heated, that is what allows it to brew coffee in a couple of minutes. The exception would be vacation (away from home) or other times when you won't be using it for a few days. Visit www.bunnomatic.com if you have lost your user manual.
Dec 31, 2009 | Bunn Pour-Omatic Coffeemaker, 10 Cup White
Bunn STPF-15, Pot overflows, Intermittently.
The sprayhead tube has scale buildup, use the deliming spring to clean tube and then clean sprayhead.
Oct 23, 2009 | Coffee Makers & Espresso Machines
Constanly leaks
Hello. Here is the owners manual for your unit that tells how to clean and delime your machine, if it requires parts, it looks like you will have to contact a local servicer, or Bunnomatic.
http://www.bunnomatic.com/pdfs/commercial/manuals/35787.0000.pdf
Hope that helps, and thank you.
Apr 08, 2009 | Bunn NHB Coffee Maker
Bunn A10 Coffee Maker Logo
599 people viewed this question
Top Bunn Coffee Makers & Espresso Machines Experts
Marvin
Marvin
pawnpower
Myrddin R Emrys
Myrddin R Emrys
Are you a Bunn Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
