Straight from the manual: (As you are facing the switch, the light level adjustment is on the upper left. The time selection is on the lower left.
1. With power restored and wallplate removed, use your finger or a small screwdriver to adjust the light sensitivity and time settings on the device as follows:
Light Level Adjustment:• Turn the control towards the "+" sign. Lights will turn ON in lighter conditions.• Turn the control towards the "-" sign. Lights will turn ON in less lighting conditions.
Time Selection:• Adjust the time selector to the desired length of time the lights are to remain ON. Lights will remain ON from15 seconds to 15 minutes after the room is vacated.
• Turn the control towards the "+" sign. Lights will remain ON up to 15 minutes.
• Turn the control towards the "-" sign. Lights will remain ON up to 15 seconds.
2. Test that the light level and time selection are as desired. If not, repeat adjustments until satisfied.
The manual is here:
http://www.leviton.com/OA_HTML/ibeCCtpItmDspRte.jsp?item=8018§ion=17219&minisite=10022
SOURCE: I installed the PR180 switch
There is nothing wrong with the switch or your wiring. The Leviton R01-PR180-1LI is not designed to work with flourescent lights. A lot of electronic controls will bleed through a small voltage when in the "OFF" state. It's just enough voltage to make the ballast in the flourescent light try to fire but not enough to let it fire the way it is supposed too.
What you need is a motion switch that is rated for flourescent lights, such as this :-( :
http://www.smarthome.com/2520W/Leviton-ODS10-IDW-Commercial-Grade-Wall-Mounted-Occupancy-Sensor-White/p.aspx
SOURCE: I have a cooper 6107
Cooper 6107 instruction sheets:
http://www.cooperindustries.com/content/dam/public/wiringdevices/products/documents/instruction_sheets/469mt_pta_rev._a_.pdf
http://www.cooperindustries.com/content/dam/public/wiringdevices/products/documents/spec_sheets/std_sensswitch_spsht_4_10_anp.pdf
3-way installation shows two motion sensor switches.
Instructions do not show 1 motion sensor and 1 ordinary 3-way switch.
Also note the maximum load rating is 500Watt
Take a moment and rate answer:
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on electrical work or any do-it-yourself project.
Fixya is always less expensive than a service call.
