Computers & Internet Logo
Posted on Feb 24, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I am attending a class on line and would like to record it. does my toshiba have that capability? I will be using headphones.
Anonymous
Level 2:
Sergeant:
  • Expert 214 Answers
  • Posted on Feb 24, 2011
Anonymous
Expert
Level 2:
Sergeant:
Answers
214
Questions
0
Helped
101986
Points
560
These two programs will work for you , the first will record audio only . the next will record audio , video and everything that happens on your computer screen .
http://download.cnet.com/Free-Sound-Recorder/3000-2168_4-10698910.html
http://download.cnet.com/HyperCam/3000-13633_4-10004511.html
1helpful
How can I hook up wireless headphones to a toshiba 40L1400U?
If it, or your receiver has a headphone jack, search on the web for "wireless headphones for tv", or visit Best But or a local electronic shop.
1helpful
2answers
MY TOSHIBA DVR19DTKB2 DVD/VIDEO RECORDER WILL NOT TURN ON AFTER I LEFT A DVD RUNNING.THE MACHINE WILL NOT OPEN TO EJECT THE DVD..WHEN I PLUG IN THE MACHINE,IT MAKES A CLICKING NOISE.THERE ARE NO 'ON'...
Always first refer to the owners manual troubleshooting. Push the power button and hold (a long time) and if no results, unplug and plug in again and repeat. I bet at some point the disc comes out. Make sure you have selected DVD on your remote.
How do you erase and change after hours greeting?dhalman
Call voicemail by pressing the Intercom button then dialing 777, when it answers login by dialing 99# followed by the password(default is 1234#) then press 9 for system features menu. Press 3 to choose Automated Attendant, the system prompts for the Auto Attendant number(1-4), start with Auto Attendant 1,if you do not know which one is being used by pressing 1. Press 2 to choose Night Menu, press 6 to change the Night Menu prompt. Lift the handset, press 1 to record your new Night Menu prompt using the handset, press 1 at the end of your recording. To listen to the new recording press 23, to immediately re-record press 21, to save the recording press *#. Press # to save all programming changes and activate new recording. Press *7 to return to system features menu or hang up to end programming session.
Changing the Auto Attendant prompt should be done when you are able to do a test call on each line to verify that you have changed the correct prompt(in your case after hours or by putting the system in After Hours mode manually to ensure the After Hours prompt is active) for each line being answered by the Auto Attendant. By default all lines are assigned to Auto Attendant 1, if your system has been modified to use a different Auto Attendant for some or all lines, you will need to repeat the above procedure for the Auto Attendant being used. If at any time you get lost or confused while in the voicemail programming, hang up and start over. Once you get comfortable with navigating the voicemail programming, it gets easier. If you have trouble send a comment, I will try to help.
1helpful
Does Toshiba Stratta DK 14 current setup offer voicemail?
A DK 14 is only capable us using the Stratagy Flash voice mail and is an external unit Grey in color. I have phones and systems that are compatible but it's not something you just "Turn On". idacomusa.com
Recording from the TV
I don't thinks it possible. Usually those cameras can record through a DV port that is two way not though an analog device.
You will have to use a Tivo, a DVD recorder, a VCR, or a computer with at TV tuner and DVR capability.
Looking for a digital camcorder with wireless mike capabilities
Any camcorder that has a mic jack can be used when you buy a wireless mic system. Otherwise some unit have built in blue tooth .
C++
Try to create a database for your class teacher to keep record of all u peoples' attendance, marks, etc., to asses the internal marks
Record audio
Do I understand correct that you want to use the headphone jack for recording ? That´s impossible, The headphone jack in just for output signals. It´s not possible to use this one for recording sound.
Top Toshiba Computers & Internet Experts
ExpressFiX
ExpressFiX
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
