Health & Beauty Logo
Posted on Feb 23, 2011
The thermometer just keeps reading a flashing D and I lost the instructions on how to use it
James Fowler
Level 1:
  • Contributor 1 Answer
  • Posted on Jan 22, 2020
James Fowler
Contributor
Level 1:
Answers
Questions
0
Helped
9219
Points
D means the temperature is to low to read
1 Related Answer
frankrome
  • 78 Answers
  • Posted on Dec 11, 2010
SOURCE: How do you change the battery on a Polder Swivel
http://polder.com.p2.hostingprod.com/images/instructions/604_instructions.pdf
1helpful
The digital thermometer was flashing "lo". I assumed it needed new batteries and then replaced them. It is still flashing lo, but also showing a C reading. What do I need to do to reset it?
there should be a setting on it that changes the temp from Celsius or "c" to ferinheight and lo means that it currently isn't reading a temperature in the normal range. try running it under hot water and see if it says error or high.
My son has your safety 1st Hospitals Choice Fever Light Ear Thermometer and he has lost the instructions. Can I download them somewhere? We need to know how to use the ear thermometer. Thank you
Go to http://www.safety1st.com/usa/eng/Products/Child-Care/Thermometers/?start=0 and find your thermometer. Click on the picture, towards the bottom there is a section you can click on called instructions. Then it will bring up a new menu it will ask you to enter your product type, model, and manufacture date and you can download the instructions from there. I hope this helps.
Jun 21, 2011 • Baby Care
8helpful
3answers
How do i set the thermo sensor 433mhz to my westclox 70034 model
Hi, First check the both channel of clock and thermometer (you can see the controler in battery insertion of thermometer and you can set up channel by pressing ch button on the clock)
Next press F/C search button until the clock find thermometer and press F/C search button again.
Oct 11, 2010 • Vacuums
I need a instrution manual for a ear themoniter model no ET1200
Hi.
  • 1 Consider that most digital thermometers take a temperature in less than 30 seconds, quickening the temperature-taking process for squirmy children.
  • 2 Read the thermometer's instructions carefully. Never throw the instructions away. Keep them near your digital thermometer.
  • 3 Wipe the thermometer probe with a soapy washcloth or a tissue dabbed in isopropyl alcohol or put on a clean probe, depending on your brand of thermometer.
  • 4 Turn the thermometer on.
  • 5 Use a gentle rocking motion as you insert the thermometer into the ear canal or rectum. Never push or cram the probe into the body. Forcing it causes pain, especially if there is swelling in the ear canal or rectum.
  • 6 Listen for the beep.
  • 7 Remove the thermometer.
  • 8 Read the thermometer. If you see "ERR," you did not get good contact with the ear canal or rectum, and will need to take the temperature again.
  • 9 Use the chart insert that comes with your thermometer to see what your normal reading should be.
  • 10 Clean your thermometer probe with a soapy washcloth and/or isopropyl alcohol before storing.
  • 1helpful
    My true freezer temperature gage has a P1 flashing code
    If unit keeps proper temp. then I would think that either the thermometer sensing probe may have been damaged during the repair process or the thermometer itself has failed.
    Lost instruction manual
    http://www.rivalproducts.com/manuals/MANUALS/RO188BR_43_81844057.PDF
    That is the URL for the manual. I find their recommended temperatures tend to run about 25 degrees hot; be sure you check the internal temp with a quick read thermometer starting 15-20 minutes before it "should" be done.
    2helpful
    2answers
    Thermometer not reading correctly
    I would guess the outside thermometer has lost its calibration.
    Does it seem consistently 5, 10 or 20 degrees off all the time?
    Let me know.
    Regards,
    Top Health & Beauty Experts
    Rob Hill
    Rob Hill
    ADMIN Andrew
    ADMIN Andrew
    ADMIN Eric
    ADMIN Eric
    Are you a Health and Beauty Expert? Answer questions, earn points and help others
