Since upgrading to Leopard I can not print CD/DVDs.
Software used during problem: EPSON Print CD Version 1.4.0A
I get the following message.
The EPSON printer driver dealing with CD printing is not installed.
I have reinstalled the EPSON Print CD software and drivers but still get
the same message. Any solutions?
Tengo una Imac y no es posible imprimir ningún CD. Me indica que debo incrementarle la memoria, con el MacOs10,5,4.
First, install "epson easyprint" from the epson website. Its found under drivers and support for your unit.
Then click ok on that error message about "driver dealing with..." After you click ok on the message, you will get another window where you will find a "manual print" button. Click on this manual print button and this will take you to the next window where you have to select "A4 as the paper size" and "CD/DVD as the paper type and paper path" . After this, click print... it should start to print! This is just a workaround until epson gets a patch for leopard for print cd........hopefully
I googled Epson support and found the answer. Here it is:
Macintosh Leopard Support
Contact Support Welcome to Macintosh OS X 10.5 Leopard support for Epson products. Here you can find out how to get drivers and other Epson software for your Epson product that work with Macintosh OS X 10.5. Check your Epson product CD to see if it already contains Macintosh OS X 10.5 drivers. If the CD indicates support for Macintosh OS X 10.5, follow the instructions that came with your Epson product to install your drivers and other software. If your CD does not list OS X 10.5 Leopard, follow the Step-by-Step Instructions below. View our Macintosh OS X 10.5 Leopard FAQs.
You can find useful information on site?
http://www.epson.com/cgi-bin/Store/support/SupportSnowLeopard.jsp
Mac OS X Snow Leopard Support
Contact Support
Welcome to Mac OS X Snow Leopard v10.6 support for Epson products. Here you can find out how to get drivers and other Epson software for your Epson product that work with Mac OS X Snow Leopard v10.6.
Check your Epson product CD to see if it already contains Macintosh OS X 10.6 drivers. If the CD indicates support for Macintosh OS X 10.6, follow the instructions that came with your Epson product to install your drivers and other software.
If your Epson CD does not indicate support for OS X 10.6, DO NOT INSERT YOUR EPSON PRODUCT SOFTWARE CD IN YOUR SNOW LEOPARD COMPUTER. Follow the step-by-step instructions below to obtain the latest software and utilities for your Epson product as they may be needed for this new operating system.
Good Luck.
Apparently the latest software doesn't work with Leopard 10.5.2. I uninstalled the Epson software and installed the earlier version [driver version 3.88] that come on the Installer CD with the printer. Printing now works.
cd........hopefully
I had the same problem with an Epson R340 printer and Epson Print CD software after installing Leopard. Here's what I did. Go to System Preferences. Select Print & Fax. Select the "+" box on the lower left part of the screen. Select Epson Printer -- USB and click "Add" and "continue" in the box that comes up (if it does).
Now see if Epson Print CD will print to a CD. If it does, great. You can now actually go back to System Preferences and Print & Fax and delete the printer you just added by clicking on the "-" box and Epson Print CD will still work.
Now I found another problem with printing. The CD printing is now off center to the right and down, so in Epson Print CD program you have to click on print and from the print screen click on "Position Adjustment" in the bottom left corner. I've found the perfect position is 3.5 mm up and 3.5 mm left to make everything print perfectly. Good luck.
