SOURCE: RICOH Photocopier machine - problem
The code you are getting is actually E-101 there is not enough space on display to display the whole code so in future if you get a code again press the # key and you can see the whole code .This code is an exposure lamp code , so either your exposure lamp is blown , or got lose connections , or you moved the machine and the scanner klimed off its rails and cant go back to the hime position .Try to enter the service mode by pressing yellew c 107 and hold down blue c all in sequence ,the number 1 will star to flash , press 5 then # 810 # then 0 # switch on and of and see if it works other wise send me a reply and ill see how i can help you .thanks
SOURCE: Unable to send & receive the Fax
Try calling your fax machine with a cell phone to see if the fax answers. If not, check that the phone wire to the fax is plugged into the LINE socket, NOT THE PHONE SOCKET on the fax machine. Next, go to the MENU on the fax.You may have to check or change one or more of the following settings by trial-and error to fix the problem. BEFORE YOU CHANGE ANY SETTING, WRITE DOWN OR PRINT OUT THE ORIGINAL SETTINGS. In the MENU, find FAX SETTINGS, FAX SET-UP, or INITIAL SETUP settings. Try changing one or more of the following: PULSE/TONE, RECEIVE MODE, SEND MODE, RING DELAY, RING TIME, OVERSEAS MODE, etc.
SOURCE: Need to change fax number programmed in Ricoh, afico 3025
Press the User tools/counter button;
Touch the Facsimile features icon on the touch panel;
select Gen. settings/Adjust tab;
touch Program fax information;
touch Own fax number;
touch For G3-1, then enter your fax number from the blue numeric
keypad then touch OK.
Touch Exit, then press User tools/counter button to go to Standby mode.
SOURCE: Hi I have Ricoh Alficio 2032 copier. There is C545 error message
I'm assuming it's SC545. It pertains to temp not being correct in the fuser. Possibly a thermistor, thermal fuse or lamps are bad. It's one of the codes that need to be troubleshot and replace whatever is needed before clearing the code. This is to prevent further damage to the machine. Thanks Colin
SOURCE: My Ricoh CL7000 keeps asking to replace the yellow
The toner cartridges for the CL7000 have microchips embedded in them, so the machine knows if it's not a new cartridge. Was the cartridge you put in brand new? (And was it a genuine Ricoh cartridge?)
On those printers, the toner is pumped into a developer system and mixed with the developer before making the image. In the developer unit, the density is checked, so if it's not seeing the right mix there, one of three common problems could be causing this.
The more likely solution is to replace the yellow developer unit, which comes as a whole unit and just slides right in. That will reset your density levels and should correct the "load toner" error.
There is a spring and cushion mechanism that the toner cartridge sits on -- this mechanism can easily be popped out of place and cause problems loading the toner. Take out the yellow toner as well as one of the other colors, and see if the little black circular piece is sitting the same way for both colors. If not, just pop it back into place, using the second color as a guide.
The other likely possibility is that the yellow toner supply tube is clogged, but that doesn't happen very often. To test if it's clogged, take out the yellow toner cartridge and the yellow developer unit and turn the copier off. Use a vacuum to provide suction at one end of the tube (the toner end will be easier) and put your finger on the other end (the developer end) and see if you feel the vacuum's suction. If not, there is probably a clog somewhere in the line.
If there is no clog and you can feel the suction, you may have a bad toner supply motor.
As a side note, if you find the problem and fix it, you might still have to put a new yellow toner cartridge in to get the machine running because it will think the cartridge you already tried is empty.
Hope that helps!
