Hi every one....
i have a problem with my laptop, it hangs when playing sound through the laptop speakers, but when connecting headphones every thing runs perfectly.. i have tried all offered sound drivers by hp but nothing happened
sorry for bad english
I bouth a HP pavilion dv5 one week ago. I turned it on and suddenly is not working. It says that hte computer it was not shut down properly . Appear a lot information . I don't not what to do thanks
Is it lagging or choppy?
And I assume it's with all applications and noises such as windows noises, flash vid/audio such as youtube, mp3's in a player and dvds or mpeg movies. You might try doing a repair install of windows and see what happens from there, just make sure that you have a good windows key to use. Or you could try doing a sytem recovery to a date previous to the problem starting.
Yeah definitely sounds like hardware, sounds like it could be an odd short on the motherboard with the hdd light. Also might try running a diagnostic on the hard drive usually the manufacturer will have a testing utility. But that still doesn't really explain the hdd light. I'd just be careful with your important data. One thing you could try is directly hooking your speakers up to an audio source, but that requires taking apart the laptop. But if your laptop is under warranty then I'd try that route. If you need anything else just give me a shout.
wormy22
i think it is lagging
thanks wor,y22 but i,ve done more than 10 repairs and installations, including xp and vista, but always the same problem, could it be a hardware failure?,aaah i forgot to tell you that the hdd led remains on during the hanging and when connecting the headphones it turns of, i think it is a defect in the laptop spreakers....
I have the same problem. hdmi out and headphones work correctly, but not the speakers
any solution? thanks
