go to the file managerin your phone then on that click on the phonememory option then remove all items in the phone memory then restart your phone this will solve this problem
Tips on changing orifice size on air conditioners and heat pumps.
A smaller orifice will create these changes
1 - Takes more refrigerant charge to get the same superheat
2 - Increases capacity
3 - Decreases Energy Efficiency Ratio
4 - Increases Head pressure
5 - Increases sub cooling
6 - Reduces suction pressure
7 - Increases Watts and Amps
A Larger orifice will create these changes
1 - Takes less refrigerant charge to get the same superheat
2 - Decreases Capacity
3 - Increases Energy Efficiency Ratio
4 - Decreases head pressure
5 - Decrease Sub cooling
6 - Increases suction pressure
7 - Reduces Watts and Amps
hi, reset your phone to increased your phone memory...go to MENU >setting >restore factory setting...your phone ask for security code then you enter 12345 if your code does not change..then wait until its done and viola ,you have now a bigger phone memory..
i hope it will help you ,thanks for trusting fixya
There are 2 types of volume in your nokia phone that you can increase or decrease.
The first one is the ring tone volume. You can either increase or decrease your ring tone volume by pressing the menu key then go to settings, go to profile, select any desired profile go to personalise go to ringing volume, then increase or decrease by using the navigation button to the right or left.
The second way is to increase or decrease the volume of the speaker of your phone which i think is the cause of your question (this volume enables you to hear clear and loud the person on the other phone). You increase or decrease the volume by making a call, as soon as the call starts ringing, press the navigation key to right to increase the volume or to the left to decrease the volume.
upgrade your RAM memory ..........(better not to use different frequency RAMS this decreases the performance) refer to your motherboard manual for this...... install the good antivirus & always keep the virus away ....
so by this you can speed up your pc...
if you are using the windows xp then increase the virtual memory ... you make the virtual memory double of your RAM size ... you can do that by going to control panel>system>advanced>advanced>virtual memory settings> increase the size of the virtual memory for the drive where the OS is installed ....
any doubts reply me
i am always here to assist you
thank you
bye
dnt forget to rate my solution
