Dryers Logo
Posted on Feb 23, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
A button fell into the lent screen hole on my samsung front load dryer. i can not see it, but it is making a lot of noise.
Ned Halaweh
Level 2:
  • Expert 240 Answers
  • Posted on Feb 23, 2011
Ned Halaweh
Expert
Level 2:
Answers
240
Questions
0
Helped
49797
Points
502
Hi, what it's doing is rattling in the blower housing as your blower wheel turns.
You need to remove the entire front panel to get to it.
Best of luck.
My Samsung moisture sensor dryer turns on but just hums and won't start drying then turns off what could be wrong?
Did you check the entire vent to outside? This needs to be free of debris also.
Makes a grinding noise when i turn it on
The lint screen may be too long, is it the original part? With all the fussing around, the screen holder may have gotten knocked out of place. Probably going to have to open the machine to get things straight.
Tub thumps after nail wedges through small hole bottom and stops tub
You could have an unbalanced tub or the piece is rotating around in the outer tub and making the noise. Contact a professional to have the machine taken apart if the noise continues.
Something fell in side the lent catcher on my kenmore 70 series dryer and now its making a very loud noise how can i take it out
Was it metal? Attach a small magnet on a thin stick or string and pull the thing out. Not metal? Something else to attach an object: sticky tape, wire hook.
No luck? Call Sears and ask their repair department for instructions.
Or call Kenmore customer service for advice.
Jan 23, 2011 • Dryers
1helpful
Making noise. how to get front cover off?
your supposed to open the very top there's three or four screws in the back on the very top. push the cover back away from you and walla.
2helpful
Clean filter light flashing and making more noise than normal
There is an element where the lent screen is. It is the dry sensor. Check to see if it has lent on it.
1helpful
Drum makes noise after I unscrewed the screws inside the machine.
You will have to remove the drum from the front and replace the drum support cup kit.
Penny in dryer
you would need to remove the entire front panel and acess the blower fan to removeth penny. withthe model number i get you detailed instructs as how to get in there
Top Dryers Experts
john h
