Question about Husqvarna Garden
Have 350 saw and the stop button does not switch of the saw Inow have to pull the choke out to stop the engine.can you advise please. Thanks John Mckenna
    Guru:
  • 479 Answers
This is caused by either a faulty stop switch (check for continuity with a multimeter), one of the leads has become detached from the switch or is broken, or the lead from the switch to the chassis of the saw has gone open circuit. The stop button functions by shorting the output voltage of the magneto coil to ground.
Posted on Feb 22, 2011
6ya staff
SOURCE:
Choke trigger on the handle will not lock to start the chainsaw
more information please..
To lock the choke on:-
1. depress dead mans trigget on top of back handle
2. squeeze throttle trigger fully in.
3. slide on switch fully down to 'full choke' position. 'it should stay there'.
4. Pull saw over until it fires once.
5. click 'on' switch up one position to 'half choke'
6. pull saw over again, saw should start running and be revving high.
7. 'blip' throttle, saw should stop revving and run on tick over.
Dec 31, 2012 | Stihl MS181 14" Chainsaw
I have been trying to turn on my chain saw. Ive pulled the handle back by the trigger gave a few pull on the rope. then i pushed the button in on the side also the push the button back in by the trigger...
The chainbrake should be activated when starting the chain saw. Activate the chain brakeby pushing the front hand guard forwards.b>Cold engine Start position, 1: Set the start/stop switch in the choke position by pulling thered control outward - upward.Decompression valve: Press the valve to reduce the pressure in the cylinder and makestarting easier. Once the machine has started the valve will automaticallyreturn to its original setting.Air purge: Press the air purge diaphragm repeatedly until fuel fills thediaphragm (at least 6 times). The diaphragm need not be completely filled.Grip the front handle with yourleft hand. Hold the chain saw on the ground by placing your right foot throughthe rear handle.Pull the starter handle, 4: Pull the starter handle with your right hand and pull out thestarter cord slowly until you feel a resistance (as the starter pawls engage)then pull firmly and rapidly until the engine fires.Push down the red choke control: As soon as the engine fires which can be heard through a"puff" sound, push down on the red choke control.Pull the starter handle (6): Keep on pulling the cord powerfully until the engine starts.
Nov 18, 2010 | Husqvarna 450 e-series 18" Chain Saw
Flooding want start(New Carb)
Give the chainsaw a break by turning everything off. Flip off the on/off switch. Turn the throttle off. Push or pull the choke to the off position and deal with anything else that might need to be switched off (off is the key word). Some even suggest removing the spark plug, pulling the cord a couple of times, then replacing the plug.
By doing all this you will make the saw (and you) more comfortable and start the process of clearing a flooded engine. Just as important, you've given yourself a minute or two more to recoup.
Flooding usually prevents a saw from starting. Flooding is the major cause of a stalled chain saw engine. Flooding is caused by too much gas applied at the wrong time. You need to prevent or remedy the flooding effect. The rebooting step (step #2) will improve this condition. Another suggestion loggers make is pulling the engine's cord through 8 times with all systems off. I don't know if this actually drains the liquid gas or gives a bit more time to counteract the excess liquid gas but I am assured it works. Do it 8 times!
Now. Set the on/off switch in the "on" position. The throttle "on" position should be turned on only as a last resort. Actually, I am told some late-model chainsaws specifically instruct you to tweak the throttle - so do it if instructed. Put the choke to the "on" position. The procedure in step #3 helps clear the engine of too much "liquid" gasoline. Again, putting down the saw down for a cup of coffee or soda will sometimes do the same thing.
OK. Everything should be back on..
Make sure you have the choke in the "on" position. When you do, pull the engine cord several times through until the engine "pops" one time. A pop is a quick audible response and **** by the engine without cranking. Please, NO more than one pop with choke on or you risk another fatal flood.
PLACE THE CHOKE IN THE OFF POSITION NOW!
With the choke in the off position, pull the engine's crank cord through again. The engine should start in 1 to 3 pulls. Try it first without using the throttle control (unless recommended by the manufacturer). Colder weather or a saw just out of storage can complicate these instructions. Here is further advice from an About Forestry Forum poster: "If I haven't gotten a pop in four pulls I transition to the part throttle, no-choke position and if I haven't gotten a start in maybe 8 pulls I return to the choke position for one or two pulls. I am sure this varies with different chainsaws, but you shouldn't have to pull very many times in the choke position, even in cold weather."
If you need more help come back.Post / thumbs / testimonial are welcome!
Nov 17, 2010 | Poulan P4018 18Inch 40cc 2Cycle Gas...
Runs first 30+ sec then bogs out/dies when throttle pressed
If still under warranty have it serviced (authorized dealer not Joe's lawn mower). There should not be a fee (paid by Husqvarna). There have been carburetor problems. If you adjust it your warranty will likely be void; Joe's small engine service just as likely to void any warranty. Are you using a fresh 40:1 fuel oil mix. The will not start with choke set is normal. Start procedure in your OM says listen for sputter and disengage choke. Almost all new saws have similar start procedure.
Start Procedure
Cold:
  1. Ignition on/off to on.
  2. Set compression release – optional step even if saw is equipped with a compression release.
  3. Pull (close) choke, set fast idle (done when choke closed on some saws); pull starter and listen for an attempt to start. once heard (usually two pulls; no more than 4).
  4. Set compression release – optional step even if saw is equipped with a compression release.
  5. Push (open) choke pull starter until it starts. (usually first pull).
Warm:
  3. Pull (close) choke, set fast idle (done when choke closed on some saws) – Do not pull with choke closed.
  4. Push (open) choke, pull starter until it starts. (usually first pull).
If you have more questions or need additional help please reply below and I will get back to you. HTH & Good Luck.
Lou
Thank You for using FixYa.
Jul 30, 2010 | Husqvarna , No.455 Rancher, 20" Gas -...
How do I start rental model 96.
The drill is to pump the primer button about 6 times, set the compression release (if equipped), and close the choke. Turn on the ignition switch and preset the throttle fast idle by pressing a button near the throttle trigger while holding the throttle open then release the throttle while holding the button in. These last two parts are done automatically by the choke mechanism in late model saws. Pull the engine through rapidly until it fires (usually within several pulls). If all this fails, take the machine back and have them demonstrate the start. Hope this helps!
May 14, 2010 | Husqvarna Chain Saw 20" Bar
Place the saw on full choke with the switch on. Pull the rope until it fires. Place the saw on half choke, and pull again, and it will start running. Half choke should release as soon as you hit the trigger.
Mar 23, 2010 | Husqvarna Chain Saw 20" Bar
Husky 254 xp spark from plug but will not start plug seems to be wet
If the plug is wet the saw is flooded. Try the following to clear that condition.
Extreme Flooding by Dolfoff; Please follow this link,
http://www.fixya.com/support/t3226410
cursor down to “Best Solution”, while there click the “Was this helpful? [Yes]” button.
Once the flooding condition is cleared this start procedure works for every saw I have (7). Please read line 3 twice; both cold and warm.
Start Procedure
Cold:
Warm:
Good Luck. HTH
Lou
Feb 27, 2010 | Husqvarna Garden
Could I please have the basic start procudure for the poulan 2375 Borrowed from a friend. won't completely turn over
1) Have fuel tank full of a mixture of 50:1 gasoline and 2 cylce oil.
2) Have bar chain oil tank full.
3) Push down choke to full
4) Pull over engine 2 times.
5) Push choke off
6) Pull over engine. If it does not start you may have flooded engine ect.
Please let me know.
Feb 26, 2010 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Blowing out gas at the start. Drained and filled with fresh gas mixture. Cleaned spark plug and srayed carb cleaner in hole. Pull choke pull cord , blowing gas out of carb. Stuck float? Buy carb kit from...
No floats in chainsaw carbs. Severly flooded most common start problem with chainsaws. Read and follow the start procedure in your manual. Don't use choke on flooded engine (may set fast idle, set then turn off)!
Please follow this link, http://www.fixya.com/support/t3226410-no_spark_new_plug_but_continues_flood cursor down to “Best Solution”, while there click the “Was this helpful? [Yes]” button
Start Procedure
Cold:
  3. Pull (close) choke, set fast idle (done when choke closed on some saws); pull starter and listen for an attempt to start. once heard (usually two pulls)
Warm:
  3. Pull (close) choke, set fast idle (done when choke closed on some saws) - Don’t pull with choke closed.
Hope this helps
Lou
Oct 31, 2009 | McCulloch Garden
Cylander keeps filling with gas when trying to start
Please follow this link, http://www.fixya.com/support/t3226410-no_spark_new_plug_but_continues_flood cursor down to “Best Solution”, while there click the “Was this helpful? [Yes]” button HTH
Lou
OPEN THE CHOKE
Start Procedure
Cold:
  3. Pull (close) choke, set fast idle (done when choke closed on some saws); pull starter and LISTEN for an attempt to start. once heard (usually two pulls)
Warm:
Hope this helps
Lou
Oct 28, 2009 | Garden
Garden Logo
1,582 people viewed this question
Top Husqvarna Garden Experts
J. Bradshaw
Marvin
Marvin
dannydoesita
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
