SOURCE: manual for panasonic kx-tg5240
Here's the manual (Adobe PDF) from Panasoni's site:
http://service.us.panasonic.com/OPERMANPDF/KXTG5240.PDF
SOURCE: How many stations can a Panasonic D1232 support?
If it says D1232 on the box, it's a TD-1232. Look at the black and silver tag on the side of the KSU, IIRC the TD-1232's tag is on the lower right outside above the power cord. Three is a TA-1232 a TD-1232, and a 123210/11. Only the TD is digital (uses 72xx/74xx phones).
As far as SYSTEM phones, the TA/TD 1232 come out of the box as 8x16 devices and you add cards to expand it. These cards have -70 part numbers and are fairly difficult to find. (I think I have one or two on my shelf). If you really have a 123211, it also expands by using cards, that fit vertically in the card file with an AMP connector plugged into its face. Those are easier to find, the risk there is when you turn off the system to install them, it sometimes forgets to power back up.
Lastly, if you really have a TD with digital phones, there is an ANALOG port on the back of each digital phone that can be wired for seperate extensions (by default it's 100 more than the digital extension). You can add single line devices in those ports.(Some restrictions apply :-). For two quick phones, you might go that route.
Carl
SOURCE: PHONE CUTS TO MESSAGE AFTER 2ND RING. I WANT IT
if answering machine is on phone , go to messaging menu it should have a setting for number of rings... make sure toll saver option is off!
SOURCE: Panasonic KX TCD715 Cordless Phone user's guid
I have solved the problem by downloading the user manual for Panasonic KX TCD715 from this page.
Thanks for your help!
Greetings from an island in the Atlantic,
HelleP531
