E-Machines (T2958) PC Desktop Logo
Posted on Feb 22, 2011
I want to do a system restore . - E-Machines (T2958) PC Desktop
Anonymous
Level 1:
New Friend:
Problem Solver:
  • Contributor 7 Answers
  • Posted on Aug 25, 2011
Anonymous
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
7
Questions
0
Helped
625
Points
14
I'm guessing that you are running windows xp. If so, this page should explain how: http://support.microsoft.com/kb/306084 click the 2nd "Click here to view or hide step-by-step instructions with pictures" link and you will see step by step instuctions.
Restore point
Using System Restore to reverse system changes in Windows 7 usually takes several minutes Here's How:
  1. Navigate to the Start -> All Programs -> Accessories -> System Tools program group.
  2. Click on the System Restore program icon.
  3. Click Next > on the Restore system files and settings window.
  4. Choose the restore point that you want to use. Note: Check the Show more restore points checkbox to see more than the most recent restore points.
    Note: Any restore points that you created, scheduled restore points that Windows 7 created, and those created automatically during the installation of certain programs will be listed here. You can not use System Restore to undo Windows 7 changes to a date that a restore point does not exist.
  5. Click Next >.
  6. Click Finish on the Confirm your restore point window to begin the System Restore.
    Note: Windows 7 will shut down to complete the System Restore so be sure to save any work you might have open in other programs before continuing.
    Important: System Restore will not revert any of your non-system files like documents, email, music, etc. to a previous state. These types files are completely unaffected by System Restore. If your intention with this tool was to recover a deleted non-system file, try using a file recovery program instead of System Restore.
  7. Click Yes to the Once started, System Restore cannot be interrupted. Do you want to continue? dialog box.
  8. System Restore will now restore Windows 7 to the state that was recorded in the restore point you chose in Step 4.
    Note: The System Restore process could take several minutes as you see the "Please wait while your Windows files and settings are being restored" message. Your computer will then reboot as normal when complete.
  9. Immediately after logging in to Windows 7 after the reboot, you should see a message that System Restore completed successfully.
  10. Click Close.
  11. Check to see if whatever Windows 7 problem you were troubleshooting has been corrected by this System Restore.
    If the problem still persists, you can repeat the steps above and choose another restore point if one is available.
    If this restoration caused a problem, you can always undo this particular System Restore.
tip
WINDOWS XP SYSTEM RESTORE
System Restore is a tool that takes your computer back to a previously working state. This option is available in Windows ME, Windows XP and Windows Vista. Windows takes snapshots of critical system files, program files and registry settings and stores them as "Restore Points". If ever you should have any problem with your computer, you can "restore" your computer to one of these Restore Points, when your computer was working fine.
Please remember - System restore does NOT have any effect on your personal files such as emails, documents or photographs.
HOW TO USE SYSTEM RESTORE TO RESTORE WINDOWS XP TO A PREVIOUSLY WORKING STATE
In order to perform a System Restore, you must have administrative rights in your computer. If this is your own personal computer, then chances are that you will be having administrative rights in it, however if you are on a network computer, say for example in a computer at your workplace, then you will have to request your Network Administrator to help you.
In order to restore Windows to a previously working "Restore Point" follow the steps given below:
1. Log on to Windows with administrative rights.
2. Click Start, go to All Programs, go to Accessories, go to System Tools, and then click System Restore. System Restore starts.
3. On the Welcome to System Restore page, click Restore my computer to an earlier time (if it is not already selected), and then click Next.
4. On the Select a Restore Point page, click the most recent system restore point and then click Next.
Note A System Restore message may appear that lists configuration changes that System Restore will make. Click OK.
5. On the Confirm Restore Point Selection page, click Next. System Restore restores the previous Windows XP configuration, and then restarts the computer.
6. Log on back to your computer. The System Restore Restoration Complete page is displayed.
7. Click OK.
If you have successfully restored your computer to a previous state, and the computer is performing as it should be, you can stop here.
But if the restore process completed successfully and the computer is still not performing as you want, you can either restore your computer to a different restore point or just undo the current System Restore. In order to undo a System Restore, please continue reading.
HOW TO RUN SYSTEM RESTORE FROM THE COMMAND PROMPT?
Many times, you may not be able to run System Restore because your computer will not start up normally. But you can still run System Restore from the command prompt.
  • Click on Start -> Run -> and type in %systemrestore%\system32\restore\rstrui.exe and click OK
OR
  1. Start up the computer in Safe Mode or Safe Mode with Command Prompt
  2. At the Command Prompt type %systemrestore%\system32\restore\rstrui.exe
  3. You can replace %systemrestore% with C:\Windows, if you like
  4. You might have to select the Operating System in your computer
  5. You might also have to enter your username and password
  6. You should have Administrator Rights in your computer to do this.
HOW TO UNDO A SYSTEM RESTORE:
You may have unintentionally restored Windows XP to a previous configuration that you do not want. To undo the restoration, follow these steps:
3. On the Welcome to System Restore page, click Undo my last restoration, and then click Next.
4. On the Confirm Restoration Undo page, click Next. System Restore restores the original Windows XP configuration, and then restarts the computer.
5. Logon to the computer as Administrator. The System Restore Undo Complete page appears.
6. Click OK.
You can now run System Restore again from a Different Restore Point.
on Jul 06, 2010 • Computers & Internet
2answers
Following a System Restore on my Dell Inspiron it has come up with windowsroot system 32 ntoskrnl. The computer was not supplied with the full Window's XP home edition CD, just a Dell reinstallation CD...
If you get that message every time you run system restore, that restore point is no longer any good. You need to try a different restore point on a different date. System restore is NOT meant to be a backup. You need to be running a backup of your computer if you don't want to lose your data. Hopefully you will have another restore point, possibly earlier than the one you used, which is good. If you need to reinstall windows, you will need to get a disk. You can send me a message if you need one.
1helpful
How do i turn computer back to yesterday
If System Restore has been turned on you can restore it back to the last restore point. May not be yesterday but you can go back. Here is exactly how curtorsey of Microsoft: To use System Restore to restore Windows XP to a previous state, follow these steps:
  1. Log on to Windows as Administrator.
  2. Click Start, point to All Programs, point to Accessories, point to System Tools, and then clickSystem Restore. System Restore starts.
  4. On the Select a Restore Point page, click the most recent system restore point in the On this list, click a restore point list, and then click Next.
  6. Log on to the computer as Administrator. The System Restore Restoration Complete page is displayed.
  7. Click OK.
2answers
Need to restore computer
if you want restore your computer then just flow the step
1 start
2 all programs
3 accessories
4 systems tools
5 restore systems
after that folow the screen your will able to restore your systems
How do get to the restore options? f key? ibm m 8147-23u desktop
Dear Sir,
plz use this step for restore
  2. Click Start, point to All Programs, point to Accessories, point to System Tools, and then click System Restore. System Restore starts.
  7. Click OK.
If you successfully restored your computer to a previous state, and the computer is performing as it should be, you are finished.
If the restore process completed successfully but the computer is still not performing as you want, go to the "How to undo a system restoration after you perform a System Restore" section. If you received an error message and the restore process did not finish, or if you cannot run System Restore, go to the "Next Steps" section
The numbers and symbols above the letters dont work ? but did yesturday
TRY A SYSTEM RESTORE
  4. On the Select a Restore Point page, click the most recent system restore point in theOn this list, click a restore point list, and then click Next.
  6. Log on to the computer as Administrator. The System Restore Restoration Completepage is displayed.
  7. Click OK.
How do I restore my program for santa cruise? i have no sound.
Dear sir,
  7. Click OK.
2answers
How do restore my com. to go back a week
  3. Or you can go to start search, and type in rstrui.exe and hit enter.
  4. On the Welcome to System Restore page, click Restore my computer to an earlier time (if it is not already selected), and then click Next.
  5. On the Select a Restore Point page, click the most recent system restore point in the On this list, click a restore point list, and then click Next.
  6. On the Confirm Restore Point Selection page, click Next. System Restore restores the previous Windows XP configuration, and then restarts the computer.
  7. Log on to the computer as Administrator. The System Restore Restoration Complete page is displayed.
  8. Click OK.
Good luck ... !!!
2answers
HOW DO I DO A system restore from within windows
Click on Start/Accessories/SystemTools/SystemRestore Once there, you'll be prompted to Create a Restore Point or Restore to an earlier point in time. Select Restore to an earlier point in time and you will see a calendar. Click on the date you would like to restore to and click Continue. It's important to leave the machine alone while it performs the restore action. Once done, it will automatically reboot. After rebooting, you will get 1 of 2 messages:
  1. Your system have successfully been restored or
  2. System restore was unable to restore your computer, no changes were made to your system
Hope this answers your question. All the best!
Greg
Top E-Machines Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Andrew Chrostek
Andrew Chrostek
Level 1 Expert
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
